Wing Shape: Why is Bottom Flatter Than Top?
  • Thread starter Fawzi Da
  • Tags
    Shape
In summary: Basically, the faster the air is flowing over the top of the wing, the more lift it will generate. This is due to the higher air velocity over the top of the wing.
  • #36
boneh3ad said:
Honestly, the sentence in the video is perfectly fine. As I mentioned in my original post in this thread, if you say the longer path is the reason the air moves faster and pressure goes lower, there are really only two ways to interpret that as working, and both of them are incorrect. The most obvious of those two is the equal transit time fallacy, and the one that requires slightly more of a stretch is the Venturi fallacy. Either way, it's wrong. The most common one is what he addresses in the video.
As you probably remember, I don't agree with your interpretation of the Venturi analogy, but regardless it is a fact that the path that the air over the top surface takes requires it to move faster than the air over the bottom surface in order to satisfy continuity. If one wants to call it an inside-out Venturi, an obstruction, or just a longer path, the fact that the air is displaced requires an increase in speed, otherwise it would have to compress. I'll say it again another way: the only way to get around an obstruction without compressing is to move faster in the vicinity of the obstruction. Rather than nitpicking the limitations of the analogy, one should amplify what it gets right. In either case, my biggest complaint both about the particular chosen analogy and the unsolicited equal transit time debunking is that so much time is spent pointing out things that aren't quite exactly right that people (not just you) never get around to explaining what actually happens.
And one day, I'm going to build an adjustable area Venturi to show that no matter how far apart you move the sides, there never ceases to be a lower pressure at the throat. But even without me building it, I think you know it is true: The A2/A1=V1/V2 ratio may break down as they move apart, but the principle that the curved surface squeezes the air and causes it to accelerate never goes away.
I have to respectfully disagree with you here. The distances will be quite nearly the same as long as the sail doesn't have too extreme of a curve.
That's the same cop-out as in the article: the less the curve and less the angle of attack, the less the lift. Of course. "Nearly" the same gets further and further from being the same the greater the curvature and greater the aoa, thus greater the lift. Or more directly: the difference in the path lengths is directly related to how much lift is generated.
In reality, barring flow separation or speeds high enough for compressibility to be a factor, most of the flow does follow the surface of a shape and the flow does not "pile up" at all.
The piling-up and stretching-out of the streamlines is quite evident in flow visualizations:
The streamlines start-out nearly uniformly distributed, but in the area of the stagnation point (one streamline is just a touch below the stagnation point) they look to me to be about 10x further apart than at the top of the airfoil. If one isn't getting squeezed perpendicular and the other smooshed lengthwise, I'd like to hear what you would call that!
  • #37
It is not an inside-out Venturi. I cannot stress that enough. Treating it as such results in a number of incorrect conclusions, not the least of which is a completely incorrect calculation of the velocity field. Consider that if it was an inside-out Venturi, it would also require the air to move faster over the bottom and have a lower pressure than it does in the free stream. This is often the case, but not always, and that fact flies in the face of the Venturi analogy. It is simply incorrect. For more on that, see NASA.
It is also a problem to say that the path over the top requires it to move faster than over the bottom. That statement implies that it even makes sense to treat the two surfaces independently in the fluid-dynamic analysis, and it does not. If you change the bottom surface, it will change the flow over the top and vice versa. They are a coupled system. So yes, the air does move faster over the top, but it is due to the whole shape, not just the shape of the top.
This flies in the face of the entire argument you just made about the video. You sat there and nitpicked the first sentence even though it was essentially correct.
I've explained time and again what actually happens on this site, and in fact, have put together an Insight that addresses this whole issue that is currently going through some iteration. Maybe that will clear it up more permanently. Suffice it to say that it has to do with the trailing edge shape and viscosity. If there was no viscosity, there would be no lift and the stagnation point would end up on top of the airfoil somewhere. Due to viscosity, there is essentially separation enforced at the sharp trailing edge (it works with a flatback airfoil, too), and the rest of the flow field must react to that viscosity-enforced stagnation point location. At that point it's just conservation of mass and momentum. The net result is that you end up with a circulation around the airfoil, or a bound vortex. This is why you sometimes see lift discussed in terms of the circulation around it, called the Kutta-Joukowski theorem.
Of course there would always be a slightly lower pressure, though you would rapidly reach the point where that difference is not measurable. Give me the accuracy of your pressure transducer and I can even tell you when that pressure difference is no longer measurable. And yet, with an airfoil, with the "walls" at infinity, there is still a drastic pressure change. It is not the Venturi effect, has little if anything to the Venturi effect, and cannot be predicted by the Venturi effect.
I don't think you get what I meant there. The reason the path would be longer with a large curve is that at some point you will end up with a large recirculation bubble inside the sail, and the free stream will track around that. In the absence of that, it will follow the sail. The difference in path lengths is not directly related to how much lift is generated. That logic would then lead to the conclusion that any airfoil whose bottom path is longer generates negative lift, and that is not true.
The streamlines start-out nearly uniformly distributed, but in the area of the stagnation point (one streamline is just a touch below the stagnation point) they look to me to be about 10x further apart than at the top of the airfoil. If one isn't getting squeezed vertically and the other smooshed horizontally, I'd like to hear what you would call that!
Ah, I see what you were saying now. This is exactly the concept of a streamline. Streamlines are defined such that no mass flow can cross them, so if you take any two streamlines in the flow, the region between them can essentially be treated as a quasi-1D control volume called a streamtube. So when you look at the streamline spacing there, they get closer when the velocity increases since the same mass flow passes between them but with a higher velocity. That is a direct application of the Venturi effect.
Likes cjl
  • #38
You're trying to harness your own self-contradiction: yes, it is often the case that the air moves faster and results in a pressure drop along the bottom surface. Most obviously, in a symmetrical airfoil at zero aoa, which, not coincidentally, looks very much like an inside-out Venturi! As the two sides present less symmetrical profiles to the air, the pressure profiles necessarily change. That doesn't fly in the face of the analogy, that is the analogy!
Terrible site. Their first objection is the flat statement that a wing is not a Venturi. I should point the to the dictionary.com listing for the word "analogy" because they clearly don't get the point. As with what you are objecting to, all of these objections peck around the periphery without actually addressing the point of the analogy. Most of the other details you provide, so I won't go point by point through the site.
That's a self-contradiction. How can saying the air over the top surface moves faster than over the bottom be treating them separately? They are both right there next to each other in the same sentence.
Still, you can have an airfoil that only has a top surface and no bottom surface. Cars are like that, or even more so any object attached to the ground that wind blows over causes a pressure drop above it. That's what causes roofs to lift off houses in wind storms. Wind wake analysis shows the higher velocity and lower pressure (than freestream) over the top of the building: http://www.advantech.vn/vi/tin-tuc/tin-ansys/1951-mo-phong-ansys-cfd-va-wow-giup-giam-thieu-thiet-hai-do-bao.html
Sorry about the translation: look at the last two images.
You have that exactly backwards: You're right that the first sentence is basically correct: the narrator is the one who nitpicked it, not me! I merely pointed out that what he was nitpicking wasn't even in his own premise! Again, that video is just like how here and in a lot of other places, people jump into debunk the equal transit time fallacy when it isn't being invoked. I don't think that's a coincidence: think equal transit time debunkers wrongly believe that for two streamlines to separate and then meet up again, they must meet in the same alignment. That's why whenever they hear someone say the two streamlines separate and meet up, they wrongly conclude that the statement requires them to align and wrongly invoke/debunk the ETT fallacy.
That describes why air goes over the top or bottom surface (why the stagnation point moves down as the angle of attack goes up, for example), but does not address the question of why the air going over the top surface moves faster than the air that moves over the bottom surface (or faster than freestream). And don't look now, but if we dip a toe into what happens at the trailing edge, we could blame Kutta-Joukowski for the equal transit time theory. (from the wiki: "fluids moving along the lower and upper surfaces of the airfoil should meet at the sharp trailing edge").
I erred earlier when I said the A2/A1=V1/V2 ratio doesn't hold for a wing. It does, just not as directly/globally as for a Venturi: for any parcel of air, its own cross sectional area and velocity are always inversely proportional as it moves along its streamline.
This simply isn't true. The wind wake analysis link shows a substantial pressure drop associated with flow over the top of a building even though there is no "bottom surface" to the wing or "other side" of the Venturi tube.
You were arguing to look at a smaller curve, not a larger curve. I don't think you got what *I* said, because I said almost exactly what you just did: I said "piles up" instead of "recirculation bubble" but in either case, we agree that the air does not follow the curve of the sail, which is precisely why the claimed example doesn't work as it claims it does. Reducing the camber/aoa is an attempt to hide that flaw. But it can only reduce the magnitude, it can't make it go away.
I'd like to see an example that satisfies your counter-claim. I can't prove a negative, but what I can say is that if you flip an airfoil upside-down (at zero aoa in both cases) so its bottom path length is now longer, it does indeed generate negative lift.
And just to head-off a potential misunderstanding: that is the path length of the parcel of air, not the distance between the geometric leading and trailing edge of the airfoil. If you flip an airfoil over, then give it a ridiculous positive angle of attack, the stagnation point moves way down the "bottom" surface, providing a longer path over the "top".
Precisely. Perhaps that renders much of the rest of this discussion moot, but since I already typed-out the whole thing over the past hour, I'm still going to hit "post reply"...
  • #39
boneh3ad, I think most of the problem here is a mismatch of two peculiarities of each of our presentations:
1. I didn't do well in my aerospace studies (thus switched to mechanical), which makes many of my presentations imprecise ("piles up" instead of "recirculation bubble") even if the issue at hand is correct (we both agreed that the airflow does not follow the "bottom" curve of the sail).
2. You have adopted a level of rigor (again likely because of your education) that doesn't allow for any imprecision and thus causes you to see only all-or-nothing answers.
  • #40
That is not correct though. It is 100% coincidental that a symmetric airfoil looks like an inside-out Venturi. The problems with the model only increase if you add angle of attack or if you remove the symmetry. Like I pointed out before, not all lift-generating airfoils have a longer path over the top, and the Venturi model would say these have to generate negative lift. That is not true. The Venturi model also would imply that the pressure on the bottom has to be lower than ambient. That also is not true.
Then what exactly is the point of the analogy? I thought the point of the analogy is to address why the air must move faster over the top, thus the lower pressure. That same analogy also implies that a longer path must produce a faster flow than a shorter path, which, again, is false. If the point is just to give a simple analogy so that people can see it should go faster without resorting to equal transit time, it still fails because it still does not describe why the flow goes faster. The fundamental mechanism is different and it leads to wrong conclusions if you get people to start thinking along those lines. That isn't why it should go faster over the top.
In your post, you simply said that the path over the top requires the air to move faster. That implies that the air over the top will move faster simply because of the shape of the top without regard for the shape of the bottom, which is not a true statement. Further, the entire concept of the Venturi analogy implies that you could treat them separately. It basically implies that you can draw line down both stagnation streamlines and say that the flow above and below those are uniquely determined by the airfoil shape above and below those. That also is not the case. That is another place where the Venturi analogy fails.
This is obvious and I have never contradicted this, Although, a car absolutely does have two sides unless it has no wheels and is skidding on the ground, in which case you are probably in a James Bond car chase. Also, in the case of the house, this still is not due to the Venturi effect. With a car, on the underside there may be some Venturi-like physics going on, but it is substantially more complicated since viscosity causes air to "stick" to both the underside of the car and the pavement, so it is actually more like Couette flow.
I wholehearted disagree with this. I'd consider myself in the "equal transit time" debunker category, and that is because equal transit time is wrong. Of course streamlines can meet back up, and by definition, they have to be in alignment because no two streamlines can every cross each other due to continuity. That doesn't require equal transit time or anything, it just requires conservation of mass. Now that that is out of the way, my issue with the original post where I cautioned JBA with his response is because his answer invoked the "longer curved path" of the top surface compared to the bottom. The only way this statement can lead to lift is via either the equal transit time fallacy or via the Venturi fallacy, both of which are provably incorrect. That is also why my response there mentioned both of them since he didn't specify exactly why the longer path causes faster flow.
It absolutely does explain why the air moves faster over the top. In fact, what I said there tells you that as angle of attack increases (barring stall), the trailing stagnation point does not move. It stays at the trailing edge. The leading stagnation point does, which changes the profile and changes the lift and drag. If viscosity was absent, the trailing stagnation point would be free to move as well and would move in tandem with the leading edge stagnation point, resulting in no net circulation, no net pressure force, and no lift. Precisely because the leading stagnation point is free to move and the trailing stagnation is fixed, however, changing angle of attack also changes the circulation, which changes the velocity over the top, which changes the lift.
First: you should know better than to trust Wikipedia for everything, especially an issue as obviously contentious as lift. Second, the quote you supplied doesn't even support your premise here. It says that the fluids meet back up at the trailing edge, not that the same parcel has to meet up with the one that split from it at the beginning. It is simply a statement of smooth flow, aka no separation/stall and no voids in the medium.
It is true, and it is provably true. Take some duct with area ##A_1## at the inlet and velocity ##v_1##. It constricts to ##A_2## and ##v_2##. Clearly, ##A_1 v_1 = A_2 v_2##. Now, assume we keep moving the top wall up by small increments ##dA##. This gives ##(A_1 + dA)v_1 = (A_2 + dA)v_2##, or ##v_2/v_1 = (A_1 + dA)/(A_2 + dA)##. Now, if we take that to its logical conclusion, where we keep adding small bits to the top duct, we end up with:
[tex]\lim_{dA\to\infty}\dfrac{v_2}{v_1} = \lim_{dA\to\infty}\dfrac{A_1 + dA}{A_2 + dA} = 1.[/tex]
In other words, at the limit of continually increasing one dimension of the duct to infinity, ##v_1 = v_2## and hence ##p_1 = p_2##. The reason the wind wake analysis still shows a sizable pressure drop is because your Venturi analogy is flawed and cannot explain lift, nor can it explain the flow over a house. Venturi cannot explain anything that does not occur in a tube with defined, rigid walls.
Yes, I was arguing for a smaller curve because with a smaller curve, no recirculation occurs, and the flow tracks right along both sides of a sail. In that case, the analogy used in the IOPScience article works just fine. With a larger curve, there is more likelihood that the flow separates and causes recirculation and the air no longer tracks the sail surface.
Take, for example, the lifting body cited by rcgldr earlier in this thread, the M2-F2.
Nope, it does not render the rest of this moot. The Venturi principle applies between streamlines, but trying to apply it to the whole wing because you can't just pick some arbitrary horizontal streamline, as I showed earlier. It changes the answer.
We don't agree to that. The airflow does follow the bottom curve of the sale provided the curvature is not to high or the angle of attack is not to high.
No, I simply call out patently false statements like the Venturi fallacy when I see them. I am here primarily to help share my fascination with fluid mechanics with others who come with questions, and when I do that, I like to make sure they understand what is actually occurring to the best of their ability. The Venturi principle has no bearing on airfoils and how the generate lift. You can tie it into why streamlines diverge or converge, but that is about it. I am all for simplified models and analogies, but not those that lead people away from the truth.
Likes cjl
  • #41
The upper surface of a wing or the downind surface of a sail curves (or slopes) away from the relative flow. The air has to centripetally accelerate towards the surface as it follows the surface to fill in what would otherwise be a void (if stalled, then vortices or mostly one large vortice could fill in what would otherwise be a void). This acceleration coexists with a pressure gradient, where pressure decreases as distance from the upper surface decreases. The reduced pressure zone also coexists with higher speed of air in the direction of the flow, since air accelerates from higher pressure zones to lower pressure zones. The relative speed of the air (wrt wing) is greatest at the lowest pressure zone.
The thin trailing edge issue mentioned by boneh3ad helps keep the flow from seperating too soon from the upper surface of a wing, but as seen with the blunt trailing edge of the M2-F2 (where the M2-F3 has rocket nozzles), doesn't prevent it from generating lift, but the lift to drag ratio is low compared to a conventional wing.
The bottom surface of a wing or the upwind surface of a sail normally exerts a centripetal force on the air causing it to curve, coexistant with a pressure gradient, one that increases as distance from the surface decreases. The increase in pressure coexists with a reduction of the relative speed of the flow.
The main thing a wing or sail has to do is divert the relative flow. A wing diverts the relative flow downwards, while a sail diverts the relative flow (apparent wind) aft of the sailboat. Newton third law pair for a wing, wing exerts a downwards and somewhat forwards force onto the air, air exerts an upwards and somewhat backwards force onto the wing.
  • #42
All through the discussions in this thread there has been something bothering me that I could not identify until the last couple of days.
Due to the fact that the majority of airfoil testing resulting in flow diagrams are performed in wind tunnels combined with the fact that we are generally taught to think in terms of "fluid flow" tends mask the fact that, in service, the correct airfoil frame of reference is a static stagnation pressure air region being impacted and displaced by moving wing rather than a static wing immersed in a flowing dynamic (kinetic) surrounding fluid. For this reason, I am becoming a bit skeptical of the standard "streamline" flow line diagrams that do not indicate any type of radial or lateral flow in surrounding air around the frontal impact region of the airfoils. It is one thing to view airfoil flow as the deflection of a moving air stream and another to view it as disturbance of a static fluid. This incorrect frame of reference can also result in statements such as the "attachment of the stagnation point to the rear point of the airfoil" given in one earlier post. Another effect of the static fluid reference is that it would appear to allow for a momentary increase and dissipation of stagnation pressure in the region of the airfoil due to the airfoil volume displacement and compression of the surrounding air medium.
  • #43
The two frames of reference are quivalent. For an airfoil moving at velocity ##U_{\infty}##, they two frames only differ by an additive factor of ##U_{\infty}##. The pressure distribution in either case is equivalent as well. I am not sure what diagrams you are accustomed to viewing, but typical streamline diagrams with an airfoil will show a disturbance to the incoming streamlines for quite a distance away from the actual airfoil. The velocities from which those streamlines are derived can also be converted directly to the other frame of reference by subtracting ##U_{\infty}##. In the case of the stationary air frame of reference, you simply get zero velocity in the flow that hasn't be influenced by the airfoil yet, and then behind it you have the velocity vectors pointing down and forward (indicating the momentum imparted to the air by the opposing forces to lift and drag respectively). Either way, this does not invalidate using the frame that follows the wing.
Further, there is nothing wrong with statements about "attachment of the stagnation point to the rear point of the airfoil", as this is exactly what happens. That is the whole point of the sharp trailing edge. That is not an incorrect statement and therefore cannot be used as a reason for why that frame or reference is "incorrect".
Also, I am not 100% sure what you mean by a momentary increase and dissipation of stagnation pressure in the region of the airfoil. At the end of the day, though, when discussing pressure, the frame of stationary air makes things more difficult, even if the eventual answer you get is the same. At issue is the fact that in this frame of reference, the flow can no longer be treated as steady-state like it can when you use the frame of a stationary wing. That means things like Bernoulli's equation no longer apply (without modification) and trying to think in terms of total pressure like is typical is more complicated. In essence, the moving airfoil adds some energy (and therefore total pressure) to the air when it passes. I believe that is essentially what you meant with the "increase and dissipation" of stagnation pressure but I thought I'd clarify.
  • #44
Newton's second law is invariant with respect to the inertial frame of reference of the observer. So it is perfectly acceptable to describe the behavior from the frame of reference of an observer traveling at the same velocity as the wing. This is entirely equivalent to having the wing in a wind tunnel.
Chet
  • #45
Russ Watters, Thank you for your thoughtful reply to my question.
Off-topic, but in the NACA 4412 airfoil data posted in this thread, section moment coefficient varies from +.01 to -.09 depending on angle of attack (Re = 50k). My understanding, however, is that moment coefficient shouldn't vary that much (with respect to alpha) when moment is measured about the aerodynamic center.
  • #46
David Lewis said:
... in the NACA 4412 airfoil data posted in this thread, section moment coefficient varies from +.01 to -.09 depending on angle of attack (Re = 50k).
Link to an image from a thread at another forum showing a similar pattern for CM, where it's most negative at 0 Alpha (AOA).:
http://forums.x-plane.org/index.php?showtopic=64286
Likes David Lewis
  • Mechanical Engineering
  • Mechanics
11K
  • Classical Physics
