swty todd
- 70
My textbook says that the output of comparators can be "wire ORed".
What does wire OReding an output mean?
Wire ORing an output means combining multiple wire signals using the logical OR operation. This creates a new output signal that is true if any of the input signals are true.
Wiring OR an output is useful when you want to create a new signal that is dependent on the state of multiple input signals. It allows you to create more complex logic and control multiple outputs with a single input.
Wire ORing and wire ANDing are two different logical operations used to combine multiple inputs. Wire ORing creates a new output signal that is true if any of the inputs are true, while wire ANDing creates an output signal that is true only if all of the inputs are true.
No, wire ORing can only be done with digital signals. Analog signals require more complex operations such as addition or multiplication.
No, wire ORing is not reversible. Once multiple inputs are combined using the OR operation, it is not possible to separate them back into their original signals.
