Understanding WKB Approximation for E-V(x)
In summary, the conversation discusses the WKB approximation and its implications for the wavefunction. It explains that according to the equation k(x)=sqrt(2m(E-V(x)))/hbar, the wavelength is inversely proportional to E-V(x), and the amplitude changes with the variation of V(x). The equation connecting amplitude with V(x) is not explicitly stated, but it is implied that it involves momentum and velocity. The conversation also mentions the eikonal term in the expansion of the wavefunction and recommends a review by Berry and Mount for further understanding of the WKB approximation.
curious.cat
Consider E>V(x). WKB states the wavefunction will remain sinusoidal with a slow variation of wavelength $ \lambda $ and amplitude given that V(x) varies slowly. From the equation \begin{equation}
k(x)=\frac{\sqrt{2m(E-V(x))}}{\hbar}
\end{equation}, I can see that the k(x) is directly proportional to E-V(x), implying that $ \lambda $ is inversely proportional to E-V(x). I cannot understand why the amplitude should change with a variation in V(x). I do know that if E-V(x) becomes negative then the wavefunction becomes exponentially decaying in which case the wavefunction is no longer a periodic function (hence, amplitudes and wavelengths no longer apply). What is the equation connecting amplitude with V(x)? I am stuck and unable to proceed any further. Sorry about the equation numbering. I am rather new to LATEX
k(x) is only the first term in an expansion of the wavefunction into orders of ##\hbar##, the next order therm, called the eikonal, gives you the variation of the amplitude.
It should be obvious why the amplitude changes with k: ##p=\hbar k## is momentum and proportional to v. Already classically, the probability to find, say, a planet at a given point of its orbit when averaging over time is inversely proportional to v. But the amplitude of the wavefunction is the square root of this probability. Everything you ever want to know about the WKB approximation can be found in the review by Berry and Mount: http://iopscience.iop.org/article/1...678CE73A943EED846ECCF5898519449.ip-10-40-1-74
Likes curious.cat
Thank you!
1. What is the WKB approximation and how is it used in understanding E-V(x)?
The WKB (Wentzel-Kramers-Brillouin) approximation is a mathematical method used to approximate solutions to differential equations, particularly those with a rapidly changing potential energy function. In the context of E-V(x), the WKB approximation allows us to better understand the behavior of the energy of a particle in a varying potential energy field.
2. How does the WKB approximation differ from other approximation methods?
The WKB approximation differs from other methods in that it takes into account the rapidly changing potential energy function, whereas other methods may only consider the average or overall behavior of the function. This makes the WKB approximation more accurate in situations where the potential energy changes rapidly over a small interval.
3. Can the WKB approximation be used for any type of potential energy function?
No, the WKB approximation is most accurate for potential energy functions that are smooth and continuously differentiable. It may not be accurate for functions with discontinuities or other irregularities.
4. How can the WKB approximation be applied to real-world situations?
The WKB approximation has many practical applications in physics and engineering, particularly in quantum mechanics. It can be used to understand the behavior of electrons in a crystal lattice, the transmission of particles through barriers, and the behavior of waves in a varying medium.
5. Are there any limitations or drawbacks to using the WKB approximation?
Yes, the WKB approximation is an approximation and may not give exact solutions to differential equations. It may also be less accurate for potential energy functions with multiple turning points or for systems with highly excited states. Additionally, the WKB approximation may not be applicable in situations where the potential energy function changes rapidly over a large interval.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
