Word Problem (Algebra?)
  • Thread starter LLS
LLS
40
It took Bill 1.5 times as long to drive to work as it took him to drive home. If the trip was 60 miles in each direction, and the total drive time round trip was 3 1/3 hours, what was Bill's average speed in mph on the way to work?
Needs to be determined
I am at a loss of how to setup the equation.
Answers and Replies
Gallileo
Have you tried writing out what you are given first? :P
LLS
40
I don't know how to set it up.
Work = 1.5 x Home
Work + Home = 3 1/3 hours
I don't know how to do this...
symbolipoint
Education Advisor
1,573
Set Up the solution this way:
Columns for rate, time, distance; rows for ToWork and FromWork. Fill in the information according to the given facts. Your unknowns which are proportianal to each other, are the rates.
HallsofIvy
43,021
970
Work = 1.5 x Home
One of the things I would object to is that you haven't told us what "Work" and "Home" mean so that we cannot say whether it is right or not.
Of course, I understand that "Work" really mean "time required to drive to work" and "Home" is "time required to drive home from work". Yes, those two equations do represent what you are told: W= 1.5H and W+ H= 4/3 (I have shortened them a little).
If you replace "W" in the second equation by "1.5H", what do you get? Once you know what "W" is, you know how long it took him to drive to work. How far did he drive in that time? What was his average speed?
LLS
40
1.5H = 4/3 -----> .88
.88 x 60 = 53.333
average speed = 53.33 mph
Is that right? Did I confuse the numbers?
kamerling
454
It's actually W+H = 10/3. substitute W = 1.5H in that. W is the time in hours he took to get to work. To get a speed from that you use
[tex] speed = \frac {distance}{time} [/tex]
Dr Zoidburg
39
.88 x 60 = 53.333
Just a little. It wasn't helped by HoI using the wrong number! (it should read 10/3 not 4/3 - the 4/3 is correct but HoI skipped a line). Also you're only / by H in your equation whereas you should be / by W + H.
Here's how I'd do it:
Let's call the time taken to drive home x.
Time taken to drive to work is 1.5 times the trip home, making it 1.5x
So total time driving is:
to home (x) + to work (1.5x) = 2.5x
total time taken in minutes is (3 1/3)*60 = 200 minutes (I find it's easier to work out than using fractions of hours)
From there, you should be able to work out how long it took Bill to drive home (x) and thus how long it took him to drive to work (in minutes). Then divide that by 60 to get number of hours it took him and the rest is simple (hint: It is a whole number!)
Suggested for: Word Problem (Algebra?)
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
