Homework Help: Word problem Polynomialf(x)
  1. Sep 28, 2011 #1
    A rectangular shipping container that the Food Bank uses to store their tinned food, has a volume of 2500 cm3. The container is 4 times as wide as it is deep, and 5cm taller than it is wide. What are the dimensions of the container
    2. Relevant equations
    3. The attempt at a solution
    (x)(4x)(4x+5)
    = 4x^3 + 20x^2 .
    Usually when it asks for dimensions it wants the roots, However i went from factored to expanded, so wth am i supposed to do? cant use bionomial theorem b/c already know the facotred form, etc.
    Help?
  3. Sep 28, 2011 #2
    any1?
  4. Sep 28, 2011 #3
    Mute
    You have an expression for the volume: (x)(4x)(4x+5 cm), where x is in cm. What this expression says is that if you specify the depth of the container, x, you can figure out the volume. You don't know the depth, though - what you know is the volume, so you have the reverse problem. The volume given is 2500 cm^3, so your task is to find the depth x such that
    2500 cm^3 = (x)(4x)(4x+5 cm)
    (Also, double-check your expanded form - you made a mistake).
  5. Sep 28, 2011 #4
    yes, I understand what it is saying.. But what is my next step?
    Or do i just combine the first two ? 16x^2 + 20x
    Then use quadratic? or factor out? x(16x + 20 )
    Idk..
  6. Sep 28, 2011 #5
    Mute
    It's a cubic equation. You can't use the quadratic formula. You have to solve the equation:
    16x^3 + (20 cm)x^2 - 2500 cm^3 = 0
    There's no nice-and-easy cubic formula that you can use to solve this. One way to solve it would be using a calculator or computer. However, perhaps you learned some tricks in class to try and solve cubic equations with integer coefficients? It turns out the relevant solution to the equation is rather simple.
  7. Sep 28, 2011 #6
    verty
    Simplify the cubic equation into the form x^2 (...) = ..., I found it easier in that form.
  8. Sep 28, 2011 #7
    Mark44
    Staff: Mentor
    I don't see how this is helpful, since the right side won't be zero.
  9. Sep 28, 2011 #8
    Ive tried solving it and i get 16x^3 + (20 cm)x^2 - 2500 cm^3 , but there is simply no factors that will make the eq = 0, so i cant use bionomial theorem. does it mean its not solveable without technology?
  10. Sep 28, 2011 #9
    eumyang
    To make the coefficients a little bit more manageable, factor out the G.C.F. Then use the rational roots theorem. You'll find one integer root that is positive. The other two roots are complex.
    And what is this bionomial theorem that you speak of? Never heard of it.
