1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Work and acceleration
  1. Sep 24, 2005 #1
    A cave rescue team lifts an injured spelunker directly upward and out of a sinkhole by means of a motor-driven cable. The lift is performed in in three stages, each requiring a vertical distance of 11.1 m: (1) the initially stationary spelunker is accelerated to a speed of 4.06 m/s; (2) he is then lifted at the constant speed of 4.06 m/s; (3) finally he is decelerated to zero speed. How much work is done on the 69.4 kg rescue by the force lifting him during each stage?
    I have to find how much work is done by the force lifting him at each stage.
    First I found the average velocity 4.06/2 = 2.03 (i think because of asuming constant acceleration). Then i divide the distance by the average velocity to get 11.1 / 2.03 = 5.4679 s . So this is how long it takes to make it to the end of the 1st stage. Then i found the acceleration which is .7425 m/s/s. but i plugged it into the work formula and i got 572 J... but it is wrong.
  3. Sep 24, 2005 #2
    Each step is done in 11.1 m, so that makes it easier.
    W=F times distance.
    In each step the distance will be 11.1 m.
    Step 1: 11.1 = .5at^2 a=(v_f-v_i)/t
    Solve for a. Then consider what force is needed to get that acceleration (keep in mind they are working AGAINST gravity as well)
    Step 2: a=0 so force is easy to figure (again, keep in mind gravity)
    Step 3: acceleration is the same as step 1 except opposite in magnitude, so they are letting gravity help them here)
    Hope this helps
  4. Sep 25, 2005 #3
    lightgrav
    The key benefit of Work and Energy approaches
    is that you get to ignore the details of the motion
    ...like acceleration. :biggrin:
    The Work done in part 1 increases PE and KE,
    so W = m g Delta_h + 1/2 m v^2 .
    Work in Part 2 only has the Delta_PE
    Work in part 3 is Delta_PE - 1/2 m v^2 ,
    since the KE_final - KE_initial = - 1/2 m v^2 .
  5. Sep 25, 2005 #4
    touche, didn't think of that
  6. Sep 25, 2005 #5
    ok i tried the equations and i got 7700, 7557, and 7414 J respectively. The 7557 worked but the other two didn't. So i think that my v value is wrong. I used 2.03 m/s because that would be the average. But should i use 4.06m/s?
  7. Sep 25, 2005 #6
    Päällikkö
    Yes, you should use the final velocity: That's how much kinetic energy the system gets.
Similar Discussions: Work and acceleration
  1. Work and acceleration (Replies: 3)
Loading...
