Work and Changes in Kinetic Energy Experiment
In summary: Is this correct?In summary, the net external work on the system of the two blocks is equal to zero in experiment 1, as the individual forces and corresponding displacements cancel each other out. In experiment 2, the net external work is greater than that of experiment 1 because the objects are pushed a greater distance in the same amount of time. In experiment 3, the net external work is still zero, but the system gains potential energy from the spring. In experiment 4, the net external work is greater than that of experiment 1 because the object with less mass is pushed a greater distance in the same amount of time. In experiment 5, the net external work is zero as the objects do not move when
KatlynEdwards
28
In experiment 1, two hands push identical blocks of mas m toward each other across a level frictionless surface with a constant force of magnitude F over the interval from t1 to t2.
In each experiment both blocks start from rest at time t1 on a level frictionless surface; both hands exert the same magnitude for f over the interval from t1 to t2; and the blocks do not run into each other during this interval. The system is defined as the blocks and any spring or rod that may be connecting them.
Experiment 2:
Same as above, except for the hands push in the same direction.
Is the net external work on the system of the two blocks greater than, less than, or equal to that of experiment 1?
Experiment 3:
Same as experiment 1, except for the clocks are connected by a spring. The spring is initially neither compressed nor stretched.
Is the net external work on the system of the blocks greater than, less than, or equal to that of experiment 1?
Experiment 4:
Same as experiment 1, except for the mass of one of the blocks is now m/2.
Experiment 5:
Same as experiment 1, except for the blocks are connected by a rigid rod.
Total Energy = the Sum of all the individual energies (Kinetic and Potential)
Kinetic Energy = 1/2 * M * (V^2)
Potential Energy = M * Height * g
Experiment 2:
I think it would be equal to the net external work on the system in experiment 1 because it's the same force on the same mass over the same interval. And since the blocks are moving in the same directions as the forces they're positive.
Experiment 3:
In this experiment the system is gaining potential energy from the spring, so I would say that it is greater than that of experiment 1.
Experiment 4:
I think this system has less external work on the system because the mass of the second block is 1/2 that of the block in experiment 1 - thus it's lost 1/4 of the energy.
Experiment 5:
I think the external work on this system is zero because the blocks don't move when force is applied. Thus this experiment has less than experiment 1.
Is this the correct line of thinking?
Thanks!
Be careful! Work is defined as force times distance -- not force times time. (Technically, work is the dot product of force and displacement, so you have to consider the direction of the particular displacement relative to the particular force too [Edit: although I don't think it matters too much for this particular problem]).
In all the experiments, the magnitude of the forces is always the same. And the time intervals are also equal. So you really should be asking yourself which experiments cause the objects to move a greater or smaller distance [Edit: i.e. a greater or smaller distance within the time period that the forces are applied.]
Okay, so then in experiment 1, the work is zero because the work on block one cancels out the work on block two due to the opposing directions.
In experiment 2 the work is greater than 1 because there are two positive works being added together.
In experiment three, the work is still zero like in experiment 1, but the system gains potential energy.
In experiment 4 the net work is greater because the negative work is half the magnitude of the positive work.
In experiment 5 the net work is zero because the distance is zero.
Is this correct?
Sorry if I confused you earlier, but that's not quite right.
Force and displacement are both vectors. The work done by a given external force is the dot product between the individual force and the individual displacement of the object on which the force acts. Yes, the individual displacements are in opposite directions, but for this problem the corresponding individual forces are also in opposite directions.
And as it turns out in this particular problem, the direction of given force is always the same as the displacement of the corresponding object. In other words, in this particular problem, the given force and corresponding displacement are always in the same direction.
Redo the above, considering the fact that the directions of the individual forces match their corresponding displacement vector directions.
And you need to think of distance! The magnitudes of the external forces are always the same in all the experiments. The only thing that really changes is how far objects are pushed.
The greater the distance that an object is pushed (with the given time-interval that the force is applied), the greater the work.
Again, there isn't any negative work involved in this particular problem. The force and corresponding displacement vectors are always parallel.
But think about it this way. If a constant force is applied to an object for a set amount of time, will the object travel farther if the object is less massive or more massive (ignore friction)?
Now that, I agree with! :approve:
Yes, your line of thinking is correct. In experiment 2, the net external work would be equal to experiment 1 because the force and mass are the same and the blocks are moving in the same direction. In experiment 3, the net external work would be greater than experiment 1 because the spring is adding potential energy to the system. In experiment 4, the net external work would be less than experiment 1 because the mass of one block is reduced and therefore less force is needed to move it. And in experiment 5, the net external work would be zero because the blocks do not move and therefore no work is being done on the system.
1. What is the purpose of the "Work and Changes in Kinetic Energy Experiment"?
The purpose of this experiment is to investigate the relationship between work and changes in kinetic energy. This involves measuring the amount of work done on an object and how it affects the object's kinetic energy.
2. What materials are needed for this experiment?
The materials needed for this experiment may vary depending on the specific setup, but generally include an object to be tested, a force measuring device, a distance measuring device, and a method to calculate kinetic energy.
3. How is work calculated in this experiment?
Work is calculated by multiplying the force applied to an object by the distance the object moves in the direction of the force. This can be represented by the equation W = F x d, where W is work, F is force, and d is distance.
4. What factors can affect the results of this experiment?
Some factors that can affect the results of this experiment include the accuracy of measurements, the angle of force application, and the coefficient of friction between the object and its surface. Additionally, external factors such as air resistance may also impact the results.
5. How can the results of this experiment be used in real-world applications?
The relationship between work and changes in kinetic energy is important in understanding the principles of force and motion. This knowledge can be applied in various fields such as engineering, physics, and sports science. For example, understanding how different forces affect an object's kinetic energy can help in designing more efficient machines or improving athletic performance.
