Homework Help: Work and Distance help!
  1. Sep 26, 2006 #1
    I have a quick question, I need to find Work for this problem, but I don't have a distance!? The problem provides vi and vf, time, and mass, but no distance? How do i find work?
    1. A 1.50 X 10^3 kg car accelerates from rest to 10m/s in 3 seconds.
    A. What is the work done in this time? W=?
    B. What is the power delivered by the engine? P=?
    W= Force * Distance (cos theta) <-- Right?
    W=? P=? m=1500 kg vi=0m/s vf=10m/s T=3 seconds
    ******************Edit**************************
    I solved my own problem!
    x = .5 (vi+vf)time
    Anyone wanna check my work for me?
    W=? P=? m=1500 kg vi=0m/s vf=10m/s T=3 seconds x=?
    x= .5 (0+10) 3
    x= 15m
    Force = mass * acceleration
    F = 1500kg * 10...?
    F = 15000 J?
    W = 15000 * 15
    W = 225000 J...?
    Thats alot of work!?
    After somebody could nicely check my work i have one more problem...
    A skateboard reaches a speed of 35m/s from an initial speed of
    25m/s after 21KJ of work
    I THINK what the problem is asking for here is: What is the skateboarder's kinetic energy disregarding the mass of the skateboard?
  3. Sep 26, 2006 #2
    mezarashi
    Unfortunately, I don't think your approach was correct. Although, you would have arrived at the same answer (given you had used the correct value for acceleration under the assumption that it is constant), I think it is better you use concepts from Work & Energy rather than mixing in Kinematics unnecessarily.
    Firstly, the equation: [d = 0.5(Vf+Vi) x t] only works when the acceleration is constant. There is no reason to assume this from what is given.
    Going back to the first principles of work and energy: the work done on an object over a period of time or distance is equal to the change in kinetic energy of that object.
    From the question, can you calculate the kinetic energy (0.5mv^2) of the car before the acceleration? And after? What is the difference? By conservation of energy, how much energy should have been delivered?
    Power is Energy/time. If that given energy above was delivered in 3 seconds, what is the power?
  4. Sep 27, 2006 #3
    thats simple
    according to ur data,
    vi=0 vf=10m/s and t=3secs
    u can find acceleration simply by using acceleration formula
    a=(vf-vi)/t => a= 10/3 => a= 3.33m/(sec^2)
    now putting it in F=m*a where m=mass
    F=m*a
    now u can find force
    about distance u can apply
    d= (vi*t) + (a*(t^2))/2
    as Force and distance both are in hand
    W= F*d and W can be calculated easily
    after that P=W/t
    so power is also calculated
    hope u get the answer correct.........
  5. Sep 27, 2006 #4
    Ok, lets re-do this:
    vi=0 vf=10m/s t=3secs m=1500 kg
    a=(vf-vi)/t
    a=(10)/3
    a=3.3m/s^2
    d= (0*3) + (3.3(9))/2
    d= 14.85m
    F = m * a
    F = 1500 * 3.3
    F = 4950
    W = F * d
    W = 4950 * 14.85
    W = 73507.5 <--- ?
  6. Sep 28, 2006 #5
    I'd love it for someone to check my latest work :!!)
  7. Sep 28, 2006 #6
    Well
    ur work is gr8
