Work/Energy Help: Calculating Force, Work & Energy Applied to a Piano
In summary, the man exerts a force of 451.56 N on the piano, which is equal to the normal force (Fn).
megaforcetkd
A 300 kg piano slides 4.0 m down a 30° incline and is kept from accelerating by a man who is pushing back on it parallel to the incline (Fig. 6-36). The effective coefficient of kinetic friction is 0.40.
Picture attached
(a) Calculate the force exerted by the man.
N
(b) Calculate the work done by the man on the piano.
J
(c) Calculate the work done by the friction force.
J
(d) What is the work done by the force of gravity?
J
(e) What is the net work done on the piano?
J
Fg = Fn
Fgx = Fgsin(30)
Fgy = Fgcos(30)
W = F(displacement)cos@
Fg = mg = (300 kg)(9.8 m/s2) = 2940 N
Fn = 2940 N
Fgx = 2940sin(30) = 1470 N
Fgy = 2940cos(30) = 2546.11 N
Ff = uFn = (0.4)(2940 N) = 1176 N
Fx = Fgx - Ff
= 1470 - 1176
= 294 N
Can't get any of it =/
megaforcetkd said:
Fg = Fn
Gravity acts vertically, while the normal force acts perpendicular to the incline surface. They are not equal. (If the surface was horizontal, then they would be equal.)
Fgx = Fgsin(30)
Fgy = Fgcos(30)
Good. Which of those is equal to the normal force?
Fn = 2940 N
The wrong value for the normal force is messing you up.
ahhh right thanks :P.
i still can't seem to get the work done by the man on the piano though..
I do
W = (451.56)(4.0)cos(30)
Gah.. Still can't get it.. I'm on my last attempt.. If I screw it up I can't input anymore..
What force did you get in part a) ?
In part A I got 451.56 N
EDIT: Actually I inputted 451.96 but there's a 1% margin for error. I got that part right.
I do
The force he exerts is parallel to the incline, so the angle (between force and displacement) is 0 degrees not 30.
I'm still getting it wrong using cos(0). On my last try.
Are inputing the correct sign? Since the man pushes up while the piano moves down, the work he does will be negative.
More accurately, I should have said that the angle between force and displacement is 180 degrees, not really zero. :redface: (Sorry if that threw you off.)
(I usually separate the calculation of the magnitude of the work and the figuring out of its sign.)
What equation did you use to get 451 N in part A?
Since the piano is not accelerating, the net force parallel to the incline must be zero. There are three forces to consider.
Oh wait, I just had a calculation error, thanks though!
1. What is the formula for calculating force?
The formula for calculating force is F = m x a, where F is force, m is mass, and a is acceleration.
2. How do you calculate work?
The formula for calculating work is W = F x d, where W is work, F is force, and d is the distance over which the force is applied.
3. How is energy applied to a piano?
Energy is applied to a piano when a force is exerted on the keys, causing them to move and produce a sound. The amount of energy applied depends on the force and distance over which it is applied.
4. Can you explain the concept of potential energy in relation to a piano?
Potential energy is the energy an object has due to its position or state. In the case of a piano, when a key is pressed, it compresses a string and stores potential energy. When the key is released, the potential energy is converted into kinetic energy, causing the string to vibrate and produce sound.
5. How does work and energy relate to each other in the context of a piano?
Work and energy are closely related concepts. Work is the transfer of energy from one object to another, and energy is the ability to do work. In the case of a piano, work is done when a force is applied to the keys, and this work is converted into energy, which produces sound.
