Work and energy
  • Thread starter alijan kk
A body moves a distance of 10 meter along a straight line under the action of a force of 5 newtons. If work done is 25 joules, the angle which the force takes with the direction of motion of the body is:
a: 0 degree
b: 30 degree
c: 60 degree
d: 90 degree
work=fdcostheta
what formula should we use to get the degree or how to figure out it by making a picture?
Answers and Replies
42
Based on the work's definition, to be honest, the more precise version of what you wrote in the Relevant equations, you have to find ##F\cdot d,## since the force is a constant vector here. Hence by what you had, you can get ##W=F\cdot d=|F||d|\cos\theta,## which can lead you to what you want.
work = FDcos
25=5*10*cose
25=50*cos
cos=25/50
cos=0.5
but what now? 1/2 or 0.5 is equalt to what?? help
work = FDcos
25=5*10*cose
25=50*cos
cos=25/50
cos=0.5
42
The value ##0.5## you get is the cosine of the angle ##\theta,## which the the angle of the force and the displacement. Do you realize these?
Inverse cos (0.5)=60
yes but on calculator the value of cosetheta is 0.99?
can you get the answer of the given options above?
42
Now the question is given ##\cos\theta=0.5## and you have to find the ##\theta## between ##0## to ##180## degrees. Right?
Inverse cos (0.5)=60[/QUOTEo
OH! yes the inverse of 0.5 is 60 !!
but why we are using inverse cosine?
yes it is 60 by using inverse cosine theta !
That's how you find x in cos(x)
42
You don't have to apply the idea of inverse function, though the same, but just have to know what you want, with some basic knowledge of trigonometry, like ##\cos 60^{\circ}=\frac{1}{2}.##
25=(5*10)cos(x)
25/(5*10)=cos(x)=0.5
cos^-1 (0.5)=60
yes you are right if have this value memorized i would have done thi question in seconds thankyou i will memorize cos30 cos60 and cos90 values right?
42
If you keep learning other physics knowledge, then you'll keep being with these basic concepts, and finally you will memorize, or say acquire, them naturally.
a: 0 degree
b: 30 degree
c: 60 degree
d: 90 degree
work=fdcostheta
60°
Related Threads on Work and energy
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
