Solving a Midterm Physics Problem: Masses A & B with Springs
In summary: I would just add in your summary that you found the velocities of masses A and B when A descends a distance of 3 inches after B is given a slight nudge.
DCholic
Masses A and B, each having a mass of 32.2 slugs, are constrained to move in frictionless slots. They are connected by a rigid, massless rod of length L = 2 ft. Mass B is connected to two massless linear springs, each having a spring constant k = 60 lbF / ft. The springs are unstretched when the connecting rod to masses A and B is vertical.
The accompanying schematic:
https://drive.google.com/file/d/0B2-REaK_0ruSZ3cwV2dZS1VuNVE/view?usp=sharing
If B is given a slight nudge, what are the velocities of B and A when A descends a distance of D = 3 inches?
W1->2 = ΔKE + ΔPEG + ΔPEE
Masses: mA = mB = m
Take upward to be positive y and right as positive x.
At position 1:
Velocity of A: vA1 = 0
Velocity of B: vB1 = 0
Height of A: hA1 = L
Height of B: hB1 = 0
Displacement of left spring: xL1 = 0
Displacement of right spring: xR1 = 0
Finding the displacement of each spring:
(L - D)2 + x2= L2
x = 11.62 in. = 0.9682 ft -> symmetric for both springs
At position 2:
Velocity of A: vA2 = ?
Velocity of B: vB2 = ?
Height of A: hA2 = L - D
Height of B: hB2 = 0
Displacement of left spring: xL2 = x
Displacement of right spring: xR2 = x
Work:
W1->2 = 0 because there are no non-conservative forces acting on the system
Change in kinetic energy:
ΔKE = (1/2) * mA * (vA22 - vA12) + (1/2) * mB * (vB22 - vB12)
ΔKE = (1/2) * m * (vA22 + vB22)
Change in gravitational potential energy: g = 32.174 ft/s2
ΔPEG = mA * g * (hA2 - hA1) + mB * g * (hB2 - hB1)
ΔPEG = m * g * ( - D) = -259.001 slug⋅ft2/s2 = -259.001 ft⋅lbF
Change in elastic potential energy:
ΔPEE = (1/2) * k * (xL22 - xL12) + (1/2) * k * (xR22 - xR12)
ΔPEE = (1/2) * k * ( 2 * x2)
ΔPEE = k * x2 = 56.245 ft⋅lbF
Relating vA2 and vB2:
Take the origin at B's initial position.
x ≡ horizontal distance from origin to B
y ≡ vertical distance from origin to A
x2 + y2 = L2 = constant
2 * x * (dx/dt) + 2 * y * (dy/dt) = 0
2 * x * vB + 2 * y * vA = 0
x * vB + y * vA = 0
At the instant when A has moved down 3 inches:
vB2 = [ - (L - D) / x] * vA2 = -1.807 * vA2
Combine all equations:
0 = (1/2) * m * [vA22 + ( -1.807 * vA2)2] - 259.001 + 56.245
vA2 = 1.718 ft/s down
vB2 = 3.105 ft/s right
This was a midterm question. Physics enthusiasts, please give feedback my thought process. Much appreciated.
Welcome to PF!
Nicely organized. Your work looks correct to me.
1. How do you calculate the force exerted by Mass A on Mass B in a spring system?
The force exerted by Mass A on Mass B in a spring system can be calculated using the formula F = -kx, where F is the force, k is the spring constant, and x is the displacement of the spring from its equilibrium position.
2. Can you explain the concept of equilibrium in a spring system?
Equilibrium in a spring system refers to the state in which the forces acting on the system are balanced, resulting in no net force and no acceleration. In other words, the spring is neither stretched nor compressed and the masses are not moving.
3. How do you determine the spring constant in a physics problem involving Masses A and B?
The spring constant can be determined by using the formula k = F/x, where k is the spring constant, F is the force applied to the spring, and x is the displacement of the spring from its equilibrium position.
4. What happens to the spring constant if the spring is stretched or compressed further?
If the spring is stretched or compressed further, the spring constant remains the same as long as the material of the spring remains in the elastic region. However, if the spring is stretched or compressed beyond its elastic limit, the spring constant may change.
5. Can you explain the relationship between the masses and the displacement in a spring system?
In a spring system, the displacement of the spring is directly proportional to the force applied and inversely proportional to the spring constant. This means that as the masses increase, the displacement of the spring also increases, while a higher spring constant leads to a smaller displacement.
