Work and kinetic energy?
  • Thread starter kappcity06
kappcity06
90
work and kinetic energy?
i was wondering if anyone could help with this proplem:
A skier pulled by a tow rope up a frictionless ski slope that makes an angle of 12° with the horizontal. The rope moves parallel to the slope with a constant speed of 1.0 m/s. The force of the rope does 930 J of work on the skier as the skier moves a distance of 7.2 m up the incline.
If the rope moved with a constant speed of 2.0 m/s, how much work would the force of the rope do on the skier as the skier moved a distance of 7.2 m up the incline?
At what rate is the force of the rope doing work on the skier when the rope moves with a speed of 1.0 m/s
At what rate is the force of the rope doing work on the skier when the rope moves with a speed of 2.0 m/s?
all that i have is w=f*d*cos(theta) please help
Answers and Replies
kappcity06
90
ok i tried sumation of work=1/2mv(final)^2-1/2mv(inital)^2. no go. then i tried to used w=fdcos(theata) 930=f*7.2*cos(12). nothing. does speed matter when dealing with force and work?!?
nrqed
295
The formula w=fdcos(theta) is perfectly fine as well as sum of the work = final kinetic energy - initial kinetic energy.
so the work done by the rope is T d cos (theta) where T is the tension in the rope and theta is the angle between the rope and the direction of the tension, right? So the question becomes this: if the skier is pulled at constant speed at 1 m/s or at 2 m/s, what does it imply for the tension in th erope? . Is it the same at 1m/s than it is at 2 m/s? That will andwer your question.
For the power (or rate of work) of a force, you must divide the work done by the time during which the force was in action.
kappcity06
90
thank you very much
Suggested for: Work and kinetic energy?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
