Work done and friction problem
A force of 52 N is applied to a 12 kg mass resting on a bench where the force of sliding friction is 15 N. The work done in overcoming friction while moving the object 24 m is
w=fd
w=(37N)(24m)
w=888J
Does this procedure seem correct ? :) Thank you!
Answers and Replies
PhanthomJay
507
No. You have calculated the net force and net (total) work done on the object. The total work done on the object includes the work done by the applied 52 N force, and the work done by the friction force. The work done to overcome friction is the work necessary to keep the object moving at constant velocity.
What formula would I use to find the work done to overcome friction? I sort of understand but am still a bit confused
PhanthomJay
507
The work done to overcome friction while moving the block 24 m is the negative of the work done by friction while moving the block 24 m.
So it would be -888J?
PhanthomJay
507
Related Threads on Work done and friction problem
  • Last Post
  • Last Post
  • Last Post
13K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
