Work done by a Carnot engine
  1. Jul 14, 2008 #1
    An ideal Carnot engine takes in 160 kcal of heat at 110°C and exhausts some of this at 10°C. How much work (in joules) must have been done by the engine?
    2. Relevant equations
    The engine's efficiency is ε = (TH - TL)/TH.
    The hint tells me that I need to use the First Law of Thermodynamics to calculate the work, which is
    ∆U = Q - W.
    I also have the equation
    ε = |W|/|QT|.
    3. The attempt at a solution
    The efficiency is (383.15 - 283.15) / 383.15 = 0.261
    but how do I find QT? I converted the 160 Cal. to Joules and got 669888 J... but somehow that seems like a lot- is it right?
  3. Jul 14, 2008 #2
    Its a carnot engine consisting of 2 adiabatic and 2 isothermal lines.
    Use this to find QT
  4. Jul 14, 2008 #3
    So, I just sum up the work done by each of the processes?
    Sorry, but Apex (Not-)Learning doesn't say much on the subject. I may be able to sift through the cruft that they call notes to see how to do this, though.
  5. Jul 14, 2008 #4
    Sorry for the double post but I don't see an "edit" button...
    How do I find the work for each individual process? All I have to go on is the 160 kcal.
  6. Jul 14, 2008 #5
    The thermal efficiency of a heat engine is given by:
    [tex] \eta_{th} = \frac{W_{net,out}}{Q_{in}} [/tex]
    Since it is a Carnot engine you can use the temperatures of the reseviors to determine the efficiency (but you already knew this since you have the efficiency correct).
    Solve for the work since they give you the heat input.
  7. Jul 14, 2008 #6
    I got the question right. Thanks everyone. :)
