Can Magnetic Fields Actually Do Work?
In summary: B## is the magnetic field. But for neutral particles, the magnetic force is not given by this equation, because the electric field and the magnetic field cancel each other out.
fricke
39
Why magnetic field never do work?
Likes Caio Graco
sandro1994 said:
Magnetic force is always perpendicular to velocity so there is no work. (cos 90°=0)
if you pull a loop of wire (to the right) with velocity v and charge is moving perpendicular to your motion (upright) with velocity u, so which velocity does the magnetic force refer to? the loop of wire is immersed in an uniform magnetic field (toward the page)
##dW = \vec F \cdot d\vec x, ## so ## \frac{dW}{dt} = \vec F \cdot \frac{d\vec x}{dt} + \frac{d\vec F}{dt}\cdot \vec x ## in case of magnetic fields ##\frac{dW}{dt} = \vec F \cdot \vec v + \vec x \cdot \frac{d\vec F}{dt} = 0 + \vec x \cdot q(\vec a \times \vec B + \vec v \times \frac{d\vec B}{dt} ) ## note that ##\frac{d\vec B}{dt} = 0 ## since it's static so the result is ##\frac{dW}{dt} = q\vec x \cdot (\vec a \times \vec B) = q\vec B \cdot (\vec a \times \vec x) ## since this is a circular motion then ##\vec a## and ##\vec x## have opposites direction so the whole thing simplifies into ##\frac{dW}{dt} = 0## the potential difference is zero, so you might expect that it doesn't do work
Are you familiar with Poyntings theorem?
No, I haven't learned that theorem yet.
OK, so Poynting's theorem is the key theorem about energy and work in electromagnetism. I will briefly derive it here (using natural units so that I don't have to keep track of constants) for the "microscopic" Maxwell's equations. Often it is derived for the macroscopic equations, so you can easily look those up also.
Start from Ampere's law.
##\nabla \times B = \frac{\partial}{\partial t} E + J ##
Then take the dot product with E and move everything over to one side.
##0 = - E \cdot \nabla \times B + E \cdot \frac{\partial}{\partial t} E + E \cdot J##
Then there is a vector identity for the divergence of a cross product https://en.wikipedia.org/wiki/Vector_calculus_identities#Divergence_2
##0 = \nabla \cdot (E \times B) - B \cdot \nabla \times E + E \cdot \frac{\partial}{\partial t} E + E \cdot J##
Then substituting in Faraday's law
##0 = \nabla \cdot (E \times B) + B \cdot \frac{\partial}{\partial t}B + E \cdot \frac{\partial}{\partial t} E + E \cdot J##
and simplifying gives
##0 = \nabla \cdot (E \times B) + \frac{\partial}{\partial t} (\frac{E^2}{2}+\frac{B^2}{2}) + E \cdot J##
The second term is the energy density of the electromagnetic field, and the third term is the power density of the work done on matter. So the first term is interpreted as the flow of electromagnetic energy from one location to another. So basically what it says is that any change in the electromagnetic energy density must be associated with a corresponding flux of electromagnetic energy or work done on matter.
Regarding your specific question in the OP, note that the term for work done on matter is ##E \cdot J## so the magnetic field is not involved.
Likes Giovanna and fricke
That is wrong answer to the original question. Poynting's theorem is a theorem about fields governed by macroscopic Maxwell equations. There is no concept of work involved and so there cannot be any way to derive the idea that magnetic force does no work.
The work and energy interpretation of the Poynting theorem is an additional assumption, based on the idea that matter is subject to force due to field and work of this force (energy supplied to matter) per unit time and unit volume is
\mathbf j \cdot \mathbf E.
The magnetic field does not occur because of an assumption. One cannot derive that it does no work from Poynting theorem here.
To answer the original question: the statement magnetic field does no work is a little foggy, it is sometimes true, sometimes not. It is true for charged particles, because there the magnetic force is always given by the vector expression
\mathbf F_m = q \mathbf v\times \mathbf B
where ##q## is charge of the particle, ##\mathbf v## its velocity and ##\mathbf B## is the external magnetic field at the position of the particle. This force is always perpendicular to velocity of the particle. Originally an experimental fact, but nowadays this can even be taken as definition of magnetic field in theory. If total force has parallel component to the velocity, its origin is sought elsewhere, in electric or mechanical forces.
The rate of work is given by the formula
P = \mathbf F_m \cdot \mathbf v.
Inserting the expression for magnetic force, we obtain
P = q (\mathbf v \times \mathbf B) \cdot \mathbf v.
Now, this expression is always 0, irrespective of vectors ##\mathbf B## or ##\mathbf v##. Hence the rate of work of magnetic force on charged particle is always 0.
Work is a non-thermal transfer of energy. Poyntings theorem involves a non-thermal transfer of energy. Therefore it describes work.
Poynting's theorem is an equation relating EM fields with charge and current densities. It does not "involve a transfer of energy" by itself.
Adopting the terms occurring in this theorem as EM energy and work done on matter is an interpretation introduced on top of this theorem; it is not part of it. This interpretation assumes power given to matter is given by ##\mathbf j\cdot \mathbf E##. This assumption is valid in some cases like Ohmic dissipation in conductor but deficient in others, like when electro-chemical and other non-EM electromotive and ponderomotive phenomena are involved.
In macroscopic theory with regular sources, Poynting's theorem is always valid. Its work-energy interpretation is not always valid; there are electro-chemical, thermo-electric effects where work on matter cannot be handled properly with simple expressions from the Poynting theorem.
Sure. similar statements can be made of any equation in physics.
Jano L. said:
This interpretation assumes power given to matter is given by j⋅E\mathbf j\cdot \mathbf E. This assumption is valid in some cases like Ohmic dissipation in conductor but deficient in others, like when electro-chemical and other non-EM electromotive and ponderomotive phenomena are involved.
Well, the particular one that I showed was the microscopic expression, so it works for those situations at a microscopic level.
I don't doubt that.
By the way, what is your favorite version of the macroscopic Poyntings?
I don't think discussion of Poynting's theorem would be enlightening to the original question. If you have a specific question on Poynting's theorem, please post a new question here on the forum and I will check it out.
1. What is work done by a magnetic field?
The work done by a magnetic field is the energy transferred to a charged particle as it moves through the field. This work is done by the magnetic force acting on the particle.
2. How is work done by a magnetic field calculated?
The work done by a magnetic field can be calculated using the formula W = qvBsinθ, where q is the charge of the particle, v is its velocity, B is the magnetic field strength, and θ is the angle between the velocity and the magnetic field.
3. What is the direction of work done by a magnetic field?
The direction of work done by a magnetic field is perpendicular to both the magnetic field and the direction of motion of the charged particle. This means that the work done can be positive or negative depending on the orientation of the magnetic field and the particle's motion.
4. How does the work done by a magnetic field affect the motion of a charged particle?
The work done by a magnetic field changes the kinetic energy of the charged particle, which in turn affects its motion. If the work done is positive, the particle's kinetic energy increases and it accelerates in the direction of the magnetic field. If the work done is negative, the particle's kinetic energy decreases and it decelerates or changes direction.
5. Can the work done by a magnetic field be converted into other forms of energy?
Yes, the work done by a magnetic field can be converted into other forms of energy such as electrical energy. This is the principle behind generators and many other devices that use magnetic fields to produce electricity.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
