Is Work Done Always Zero in a Conservative Field?
In summary, the conversation discusses the concept of work in a conservative field and the question of whether it is zero when a closed loop is followed. The conversation also delves into the definition of work and provides examples to explain the concept. Ultimately, the answer to the question is determined to be A, as the distance moved in the direction of the force is zero in both scenarios.
mrcotton
120
imgur.com/kBTVm
Hi,
I understand that work done in a conservative field when a closed loop is followed is zero.
The answer to this question I am sure is B. How do I explain to my colllegue that it is not zero when he thinks that the speed is constant and there is no friction and the force is at 90 degrees to the velocity vector.
Thanks
Dave
Hello Dave, perhaps if you were to explain what you mean some sort of help might be forthcoming.
What is B?
Hi,
I am afraid I was unable to post the image I uploaded,
The image is hosted at http:// imgur.com/kBTVm
spaces need removing
Any help would be greatly appreciated
Thanks
Dave
Sorry but I get that page as unavailable.
In any case reference to online images etc is poor practice because that webpage may well have disappeared when someone comes to view the thread in the future.
So just explain as best you can.
Note you can go a long way writing formulae with the sub abd superscript Xs[/SUB2 and X2 in the bar above and the selectable symbols on the right.
OK I have managed to see your webpage - (spotted the space a bit late).
Why do you think your friend is wrong?
Edit it might help to state your definition of work.
A particle of mass m moves horizontally at a constant speed v along the arc of a circle from p1 to p2 (the diagram indicated a quarter of a circle) under the action of a force. What work is done on the particle by the force during this displacement?
a) Zero
b) ((pi)mv^2)/2
B being from force (mv^2)/r and displacement (2(pi)r)/4
Thanks for the tips, I will ignore my sons helpful ideas of using imgur, I couldn't even pronounce it anyway.
Dave
I am happy that the work is zero in a closed loop if the force in question is conservative.
He is saying that no work is done because the force is alway at 90 degrees to the velocity.
He also is saying that the kinetic energy is constant and that there is no friction so nothing can convert another form of energy into the work
Last time I walked around an equipotential path around a mountain I still had to have a lie down
OK we know the question.
The issue is that you are having trouble arriving at the correct answer and don't agree with your friend's explanation?
What is your definition of work?
Consider a block of ice being slid across a flat level tabletop at constant velocity.
The block of ice is subject to the force of gravity throughout but no work is done. Can you see why from the basic definition of work?
So the block of ice is sliding on ice at constant speed implying no horixontal forces. Gravity pulls the block downwards and is always acting at 90 degrees to the velocity so the dot product of the two vectors is always zero
Thanks for the help
Dave
Dot product, energy, conservative force, closed loop...
Let's keep it basic.
KISS (Keep it simple stupid)
Work is done when a force moves its point of application.
The work done equals the product of the magnitude of the force and the distance moved in the direction of the force.
First the ice block.
The ice block moves neither up nor down in its travels. So the distance moved against/with gravity equals zero.
Anything times zero is still zero.
In particular the work done is zero from the definition.
Now your example is more tricky since your particle is moving in a circle.
The only possible force that can act is directed along a radius from the particle towards the centre. It is this force that causes the particle to deflect from a straight line.
However this force must be constantly changing direction to be always radial.
Because the path is a circle the radius does not alter. That distance the particle moves against/with the direction of the force is zero.
Again zero times anything is zero so the work is zero.
This type of motion is called motion under a central force and is like whirling a stone around your head on a string.
BTW you should really post this in the homwork section. I am not a moderator, but you might find a moderator will move it.
Thanks Studiot, I like the concept of keeping things simple. I can see why the answer really is A then. This is not homework, unfortunately it is an old exam question and the exam board said the answer was B not A. It caused a bit of a debate amongst a few of us.
Thanks for your help, alas I am off to do work against gravity and climb the stairs at 180 degrees to the force.
Dave
1. What is work done in a partial circle?
Work done in a partial circle refers to the amount of energy expended or force applied to move an object along a curved path. It is a measure of the displacement of the object in a curved motion and the force required to overcome any resistance.
2. How is work done in a partial circle calculated?
The work done in a partial circle can be calculated by multiplying the force applied to the object by the distance it moves along the curved path. This can be represented by the equation W = Fd, where W is work, F is force, and d is distance.
3. How is work done in a partial circle different from work done in a straight line?
In a straight line, the force and displacement are in the same direction, so the work done can be calculated using the same equation mentioned above. In a partial circle, the force and displacement are not in the same direction, so the calculation must take into account the angle between them.
4. What factors affect the amount of work done in a partial circle?
The amount of work done in a partial circle can be affected by several factors, including the magnitude of the force applied, the distance the object moves along the curved path, and the angle between the force and displacement vectors.
5. How is work done in a partial circle related to kinetic energy?
Work done in a partial circle is directly related to the change in an object's kinetic energy. If the work done is positive, it will increase the object's kinetic energy, and if it is negative, it will decrease the kinetic energy. This relationship is governed by the work-energy theorem, which states that the work done on an object is equal to the change in its kinetic energy.
  • Mechanics
  • Mechanics
