• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Work done on a spring
  • Thread starter karobins
1. Homework Statement
A spring has a relaxed length of 7 cm and a stiffness of 150 N/m. How much work must you do to change its length from 12 cm to 15 cm?
2. Homework Equations
F=-kx, W=F(delta)x
3. The Attempt at a Solution
?? ((.12 m)-(.07 m) * (150 N/m)) = 7.5 N
((.15 m)-(.07 m) * (150 N/m)) = 12 N
(12-7.5 N) * (.15-.12 m) = .135 Nm
LowlyPion
3,079
Welcome to PF.
You need to consider that W = ΔPE
What is the formula for the PE of a spring?
thanks much for the help!
i assume you got the answer but if not
a quick way to solve this problem is to
set up a integral.
integrate Kx where K is the stiffness
so it gives you 75x^2
act like relaxed lenght is initial (or 0) then find difference
from initial your two asking points are (make sure your in m not cm)
ex. rest is 7cm find work 13cm stretched to 15 cm
first limit would be (.13-.07)=.06 next (.15-.07)=.08
just plug these in to 75x^2
do F(b)-F(a) and that gives you the answer
Related Threads for: Work done on a spring
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
