Work done PV curves
  1. Sep 13, 2010 #1
    One mole of a dilute gas initially has a pressure equal to 1.00 atm, and a volume equal to 14.0 L. As the gas is slowly heated, the plot of its state on a PV diagram moves in a straight line to the final state. The gas now has a pressure equal to 2.00 atm, and a volume equal to 78.0 L.
    (a) Find the work done by the gas.
    (b) Find the heat absorbed by the gas.
    2. Relevant equations
    3. The attempt at a solution
    I took the area under the PV curve which is a triangle... 64/2*101.325
  3. Sep 14, 2010 #2
    ehild
    Watch out: It is not a triangle. The work done by the gas is the area under the PV curve down to P=0.
    ehild
  4. Sep 14, 2010 #3
    Andrew Mason
    In addition to what ehild points out, watch the units for volume. If you are using MKS units you have to convert litres to _________.
    What is the relationship between work done, heat flow and change in internal energy? To find the heat flow, what other quantity do you have to find? (hint: what is the change in temperature?).
    AM
Similar Discussions: Work done PV curves
  1. PV work done question (Replies: 4)
Loading...
