Homework Help: Work-Energy Kinematics HW Help
  1. May 29, 2012 #1
    At a carnival, you can try to ring a bell by striking a target with a 9.00 kg hammer. In response, a 0.400 kg metal piece is sent upward toward the bell, which is 5.00 m above. Suppose that 25.0% of the hammer's kinetic energy is used to do the work of sending the metal piece upward. How fast must the hammer be moving when it strikes the target so that the bell just barely rings?
    2. Relevant equations
    W = final mechanical energy - initial mechanical energy
    1/2m*final velocity^2 + mg*finalheight = 1/2m*initial velocity^2 + mg*initial height
    Conservation of mechanical energy
    3. The attempt at a solution
    I tried setting up an equation using the second given equation, but unfortunately there are too many variables.
  3. May 29, 2012 #2
    rock.freak667
    Start simple, how much energy will it take to raise 0.4 kg mass to a height of 5 m?
    What is the expression for KE?
  4. May 29, 2012 #3
    KE = 1/2mv^2;
    or KE = mg(hf - h0)
  5. May 29, 2012 #4
    rock.freak667
    Right but they said that 25% of the hammer's KE is used to do the work, so how should you incorporate this into the equation?
  6. May 30, 2012 #5
    KE = 1/8mv^2
    or KE = 1/4mg(hf-h0)
  7. May 30, 2012 #6
    rock.freak667
    Correct.
    So now you have 1/8mv2=Mg(hf-h0)
    You know m, M,g, hf and h0, solve for v.
  8. May 30, 2012 #7
    So: v^2 = 8mMg(hf - h0)
    v = sqrt(8mMg(hf-h0))
    but what is h0? Do I assume it is 0 m?
    And there are two masses: the 0.400 kg one and the 9.00 kg one.
  9. May 30, 2012 #8
    rock.freak667
    Recheck your algebra on this one, you will need to divide by something.
    Yes it is zero.
    Right, which mass has the kinetic energy? Which mass will have the potential energy gain?
  10. May 30, 2012 #9
    Sorry, I failed miserably. The equation is
    sqrt(8Mg(hf-h0)/ m)
    Let me guess. Plug in the numbers; then, multiply this by four to get the original KE, and then solve for the final velocity.
  11. May 30, 2012 #10
    rock.freak667
    Well you already have the formula for the final velocity v.
    [tex]v = \sqrt{\frac{8Mg(h_f -h_0)}{m}}[/tex]
    So just input all the numbers.
  12. May 30, 2012 #11
    Sorry, I forget. What does capital M represent? I know lowercase m represents the mass, right?
  13. May 30, 2012 #12
    rock.freak667
    Both are mass. One is just the mass of the hammer and the other is the mass of the piece of metal.
