Calculating Work: Uniform Chain on Table with Hanging Part - IIT 1985
In summary, the question discusses a uniform chain of length L and mass M lying on a smooth table, with one third of its length hanging vertically off the table. The task is to find the work required to pull the hanging part onto the table, given the acceleration due to gravity, g. Through solving for the force and displacement, the work is determined to be MgL/9, but this is incorrect. Instead, the correct method involves lifting the center of mass, located at L/6 below the table, and using the formula for work done against gravity, which yields Mgh= MgL/6.
prateek_34gem
Uniform chain of length 'L' and mass of 'M' is lying on smooth table and one third of it's length is hanging vertically down over the edge of the table. If 'g' is acceleration due to gravity , then work required to pull the hanging part onto the table is :
A)MgL
B)MgL/3
C)MgL/9
D)MgL/18
(I.I.T :- 1985)
mass of hanging part will be m/3. so it will be exerting mg/3 force downward.
so this amount of force is required to pull it up.when the chain will be up its displacement along table will be l/3 because now hanging part is on table.
so
F=Mg3
S=L/3
Work = F*S= MgL/9
But it is the wrong answer.
Try lifting the center of mass of the hanging chain up on to the table and using the formula (work done against gravity = m*g*h).
The center of mass is halfway down the part that's hanging off, which was L/3. So the center of mass is L/6 below the table top. The mass of the hanging part is 1/3 of the total mass...Go for it.
ya i got it . thnx a ton
1. What is work and how is it related to energy?
Work is a measure of the amount of energy required to move an object a certain distance. It is directly related to energy because it involves the transfer of energy from one form to another. In order for work to be done, there must be a force applied to an object and the object must move in the direction of the force.
2. How is work calculated?
Work is calculated by multiplying the force applied to an object by the distance that the object moves in the direction of the force. The formula for work is W = Fd, where W is work, F is force, and d is distance.
3. What are the different types of energy?
There are many different types of energy, including kinetic energy, potential energy, thermal energy, chemical energy, and electrical energy. Kinetic energy is the energy of motion, potential energy is energy that is stored and waiting to be released, thermal energy is the energy of heat, chemical energy is the energy stored in chemical bonds, and electrical energy is the energy of moving electrons.
4. How does conservation of energy relate to work?
Conservation of energy states that energy cannot be created or destroyed, only transformed from one form to another. This relates to work because when work is done, energy is transferred from one form to another. The total amount of energy before and after the work is done remains the same.
5. Can work be negative?
Yes, work can be negative. This occurs when the force applied to an object is in the opposite direction of the object's motion. In this case, work is considered to be done against the force, and the work is given a negative value. For example, if you push a box up a hill, the force you apply is in the same direction as the box's motion, so work is positive. But if you push the box down the hill, the force you apply is in the opposite direction of the box's motion, so work is negative.
