Why does it feel like work when holding something up?
  • Thread starter Pengwuino
  • Tags
    Work
In summary: The example at right is another standard paradox in the definition of work. If the box is being carried at constant velocity, then no net force is necessary to keep it in motion. The force exerted by the person is an upward force equal to the weight of the box, and that force is perpendicular to the motion. If there is no motion in the direction of the force, then no work in done by that force. Yet you certainly feel like you are doing work if you carry a heavy box. The resolution of the paradox is similar to the first example - your muscles must maintain an extra tension to stay upright under the load. This requires a greater amount of internal contraction and release of our muscle fibers, and hence internal work in our bodies. But
Pengwuino
Something I've always wondered is why does it feel like work is being done when you're just holding something up. According to the definition of work, 0 work is being done if no displacement occurs... but no one can say with a straight face that you aren't doing some form of work somewhere when you hold a 100lb bag up or something. Maybe this is a biology question but where exactly is energy being consumed/used when a human being holds something up in the same position? Or is it even possibly just a mental trick that it feels like some work is being done (maybe its just neurological signals)?
I'm no expert but here's my guess. In order to keep the object from falling you have to exert an upwards force to counteract gravity. Our muscles have to tense in order for this to happen. This is a biological process which uses energy, but I'm not quite sure what the process is.
Ya I am not 100% sure what the best answer to that would be but i would say its got more to do with the definition of work. Theres 0 work done on the bag because it dosent move. But you arm is definately using energy (ATP and all that chemical energy in the body). And if you think about it your arm is creating the normal force, so basicaly your applying as much force as a table would on the bag. I am not sure if that really answered the question at all but it was worth a try.
When you're holding something up (stationary), your muscle cells are alternately contracting and relaxing and moving back and forth. So they're indivdiually doing work, but they're fighting each other so the work probably gets dissipated as heat.
For details, you'll have to ask a biomechanics or biophysics expert.
No it does not answer my question skigamemaker. I think jtbell is right in directing me to a biologist or biphysicist.
The example at right is another standard paradox in the definition of work. If the box is being carried at constant velocity, then no net force is necessary to keep it in motion. The force exerted by the person is an upward force equal to the weight of the box, and that force is perpendicular to the motion. If there is no motion in the direction of the force, then no work in done by that force. Yet you certainly feel like you are doing work if you carry a heavy box. The resolution of the paradox is similar to the first example - your muscles must maintain an extra tension to stay upright under the load. This requires a greater amount of internal contraction and release of our muscle fibers, and hence internal work in our bodies. But the work done on the box is zero since by moving in a straight line at constant speed, it's energy is remaining the same.
http://hyperphysics.phy-astr.gsu.edu/hbase/work2.html
Rather than type, I will just copy and paste. Jtbell already gave you the answer.
So its the contraction and release of muscles... well i have no knowledge of that so i'll go see how that all works. Thanks guys.
You did answer your own question in the question, but consider this: why is it easier to stand up straight than to do a "wall sit" (leaning back against a wall in a seated position)?
It's just a net work of zero on the system because work is being done by gravity downward while you do work in the opposite direction. Take away gravity and you will start pushing the object up.
No work is being done on the object (by you or by gravity) since the object doesn't move. The work being done to maintain muscle tension is internal to your body.
Mechanical work is not being done. No displacement, hence no work. There was a thread similar to this in the intro physics sections not solong ago, I'll try and see if there's anything useful in there.
~H
[edit]Sorry, Doc you beat me to it again :wink:
Work is being done by the heart in pushing blood through arteries, veins and capillaries -there is force and there is displacement in the direction of the force. However, as Russ indicated, no work is being done on the object which should be evident from the fact that its kinetic and potential energies are fixed.
Muscles convert chemical energy into mechanical energy. Probably the best way of looking at the issue is to say that your muscles are operating at 0% efficiency when you hold a weight over your head, or do isometric exercises.
Chemical energy is still being used by your body (the ADP/ATP metabolism involving your mitochondria) - but none of that energy is doing any actual work. You feel like you are doing work because your body is actually using up chemical energy stores (the ATP molecule). Unfortunately, the efficiency of work output is 0% in the case of isometric exercise or when you hold a weight "over your head".
You can see that no mechanical work is being done by considering a stretched spring, for instance. The spring is stretched, and exerting a force, but it (the spring) never "gets tired" or "runs out of energy".
Similar remarks can be made about tables - they can hold up weights, they also do not "get tired" or "run out of energy".
You're confusing the physics definition of work with the colloquial meaning of work.
What is work?
Work is a measure of the energy transferred when a force is applied over a certain distance. It is commonly measured in joules (J) and can be calculated by multiplying the force applied in newtons (N) by the distance traveled in meters (m).
How is work related to holding something up?
When you hold something up, you are exerting a force against the force of gravity. This force must be equal to the weight of the object in order to keep it from falling. The distance that you hold the object up is also a factor in determining the amount of work being done.
Does holding something up require work?
Yes, holding something up requires work because you are exerting a force against the force of gravity over a certain distance. Even if the object is not moving, work is still being done to keep it in place.
What factors affect the amount of work required to hold something up?
The amount of work required to hold something up depends on the weight of the object, the force exerted, and the distance over which the force is applied. The greater the weight of the object or the longer the distance it is held up, the more work is required.
Is holding something up considered a form of exercise?
Holding something up can be considered a form of exercise, depending on the weight of the object and the duration of time it is held up. It can help build muscle strength and endurance in the muscles used to hold the object up.
9K
