Work of a heat engine
  1. Dec 6, 2006 #1
    An engine works at 26% efficiency. The engine raises a 6-kg crate from rest to a vertical height of 11 m, at which point the crate has a speed of 5 m/s. How much heat input is required for this engine?
    2. Relevant equations
    e=work output / heat input = W/Qin
    W=Fd
    3. The attempt at a solution
    I assume the velocity is insignificant since W=Fd; W=(6*.981)*(11)= 647.46J
    .26=647.46J/Qin
    Qin=.0004016 J
    the value for calculated heat is wayy too low; where did I screw up? Thanks
  3. Dec 7, 2006 #2
    Andrew Mason
    For starters, you have calculated 1/Qin not Qin.
    You are also ignoring the work that is required to give the load the kinetic energy. Add that to your calculation for W and then do the algebra properly and you will be fine.
    AM
  4. Dec 7, 2006 #3
    for KE do I just say that delta E = 1/2mv^2 + mgh = W = eQ ?
    .5(6kg)(5^2)= 75J
    mgh = 647.46J
    What do i do with these two values?
  5. Dec 7, 2006 #4
    Andrew Mason
    Looks good to me.
    Why not put them into your equation and find Q?
    AM
