Work on an inclined plane
  • Thread starter bobbob
bobbob
A block of mass M is being puled up an inclined plane at a constant speed, by an attached rope that exerts a tension T. The block is pulled a distance L. The plane makes an angle theta with the horizontal, and the coefficient of kinetic friction between the block and the incline is uk.
a) Let E=PE + KE of the block. What is the change in the mechanical energy E of the block? What is the change in the potential energy of the block?
b) Verify that deltaE = Wnoncons, the change in the mechanical energy of the block is equal to the work done by the non-conservative forces acting on the block.
c) what is the Wgrav, the work done by gravity on the block? Check that Wgrav = -delta PE.
d) Combining your results find the total work done on the block, Wtot = Wcons + Wnoncons.
Verify that Wtot = delta KE
any help would be much appreciated..not sure how to do this part. thanks
Answers and Replies
LowlyPion
3,097
Welcome to PF.
Start with a) then. The block moves at constant speed, so what is the Δ in KE? It moves L, at an angle of θ, so how much higher does it get after moving L? What does that make the Δ in PE of gravity?
For the rest of it, what is the non-conservative force? Friction? And the work to friction is what? W = F*d = μ *m*g*cosθ ?
Suggested for: Work on an inclined plane
  • Last Post
16K
  • Last Post
  • Last Post
15K
14K
12K
  • Last Post
