Homework Help: Work Power and Energy Help
  1. Apr 24, 2006 #1
    Ok so I'm in Gr 11 U Physics and we have an assignment and I have a couple q's
    1) While at the park a child sits on top of a 3.5m slide. When he reaches the bottom of the slide, he is travelling at 3.0m/s. Calaculate the efficency of the slide
    2) A 5000 W motor is lifting crates from the bottom of a mine shaft to the ground above at a constant rate of 5m/s. What is the maximum weight of a crate to be lifted up the shaft?
  3. Apr 24, 2006 #2
    Hootenanny
    Staff Emeritus
    Welcome to PF Kaity,
    The policies of this forum prevent us from helping you, unless you show some working or initial thoughts...
    ~H
  4. Apr 24, 2006 #3
    ok well for the first one...we did something similar in class, but when I tried it, it was definetly wrong. we were told to not include mass when it is not given so for this it would be:
    Eg = mg x h Ek= 1/2mv2
    = m(9.8)(3.5) =(0.5)m(3.0)2
    =34.3mJ =4.5mJ
    %e =Eg /Ek x 100%
    = 34.3mJ/ 4.5m/J x100%
    = 762.2%This answer is evidently wrong
  5. Apr 24, 2006 #4
    for the second one I have no idea where to even begin
    P=5000W or J/s
    v= 5.0m/s
    So I originally tried figuring out force which you can get by doing
    F = P/ V
    = 5000W/5.0m/s
    = 1000N
    and I believe you can find the mass of that by dividing the
    1000N/9.8 = 102.04kg
    is that it or is there more to it?
  6. Apr 25, 2006 #5
    Hootenanny
    Staff Emeritus
    First, you need to find the energy lost;
    [tex]E_{lost} = E_{inital} - E_{final[/tex]
    Then you need to find the efficency;
    [tex] = 1- \frac{E_{lost}}{E_{initial}}[/tex]
    Can you go from here?
    ~H
  7. Apr 25, 2006 #6
    First off, I solved the 5000W motor problem using different equations and arrived at the same answer, so I would say that your calculation of the mass is correct. What I did was realize that since power is work over time, and the work will be the increase in potential energy in this case I could replace work with mgh (where m is mass, g is acceleration due to gravity and h is the change in height) and then solve for m. That method yielded your answer.
    For the slide question, you stated that %e=Eg/Ek*100. In my class we said that %e=(energy out)/(energy in) * 100. I think that will give you a much more reasonable result.
