Calculating Force Needed to Pull Chain Onto Table
In summary, the conversation discusses how to calculate the work required to pull a chain onto a table, taking into consideration the force of gravity and the concept of center of mass. It is determined that the work needed is 12.7 joules.
goonking
434
W = F d
F = ma
so in order to get the whole chain on the table, we need to pull the chain 0.65 meters onto the table.
since 0.65 meters is hanging off the table, the gravity is acting on it, therefore F=ma where m is half the chain (8kg /2 = 4kg) and a = gravity(g), which is 39.2 N,since we work against this force we need to find the force required to pull 8 Kg a distance of 0.65m and then subtract 39.2 N.
is this the correct approach?
As you pull it up the force required get less. I would use a different approach.
Hint: Work = change in energy
W = KEf - KEi
KEf = 0 since v =0
KEi = mgh = 8 kg x 9.8m/s^2 x 0.65 = 51
W = 51 Js
is this correct?
Close.
How much mass changes height?
Where is the centre of that mass and how much height does it gain?
CWatters said:
Close.
I didn't learn about center of masses yet , is that required to do this problem? :(
There is another way but I suspect its a lot harder.
Read up on the centre of mass or centre of gravity.
Consider a uniform ruler that's 12" long. To find the centre of mass you could balance it on a knife edge to make a seesaw (tetter-totter in the USA). If you adjust the position of the ruler until it balances the centre of mass will be found to be around the 6" position.
The centre of mass of the part hanging over the edge would be at 0.65/2 = 0.325m below the top of the table.
then wouldn't we need to find the center of mass for .325m and so forth?
No.
The part of the chain that hangs over the edge can be replaced/modelled by a single 4kg mass on a rope that hangs 0.352m over the edge.
CWatters said:
No.
so the work required to pull the lingering half of the chain up is 4kg x 9.8 x .352m?
and the work required to pull the other half which is already on the table is : W = F d
we just need to add (F d) + (4kg x 9.8 x 0.352m) right?
Correct.
No. It actually takes no energy/work to move that bit along the table. The problem states you can ignore friction so the "F" in W = Fd is zero.
CWatters said:
Correct.
ok, i got the answer to be 12.7 j
I agree.
What is a work problem chain on a table?
A work problem chain on a table is a physics concept that involves analyzing the forces acting on an object placed on a flat surface, such as a table. It helps to understand the relationship between these forces and how they affect the object's motion.
What is the purpose of studying work problem chain on a table?
The purpose of studying work problem chain on a table is to understand the fundamental principles of physics, specifically the concept of work, and how it relates to forces. It also helps in solving real-world problems involving objects on flat surfaces.
What are the key components of a work problem chain on a table?
The key components of a work problem chain on a table include the object placed on the table, the forces acting on the object (such as gravity, normal force, and friction), and the displacement of the object.
How do you determine the net work done on an object in a work problem chain on a table?
The net work done on an object in a work problem chain on a table can be determined by calculating the total work done by all the individual forces acting on the object. This is represented by the equation Wnet = W1 + W2 + W3 + ... where W represents work and the subscripts denote the different forces.
What are some examples of real-life situations that can be analyzed using work problem chain on a table?
Some examples of real-life situations that can be analyzed using work problem chain on a table include pushing a box across a table, lifting a book off a table, and sliding a book across a table with varying amounts of friction. These scenarios involve forces acting on an object on a flat surface and can be solved using the principles of work and energy.
