Work problem
  • Thread starter cyspope
cyspope
27
67. How fast must a cyclist climb a 6 degrees hill to maintain a power output of 0.25 horse power? Neglect work done by friction and assume the mass of cyclist plus bicycle is 70 kg.
A. 2.6 m/s
W = mgh = Fdsin[tex]\theta[/tex]= [tex]\frac{1}{2}[/tex]mv[tex]^{2}[/tex]
(0.25 hp * 735.5 W * 3600 J) = 70 * 9.8 * h * sin(6) = [tex]\frac{1}{2}[/tex]*70v[tex]^{2}[/tex]
661950=71.707h =35v[tex]^{2}[/tex]
I don't get how the answer should be only 2.6 m/s.
Answers and Replies
godtripp
54
I think your equations may be confusing you.
For instance what is h? h or (d) should be the distance that the cyclist is traveling.
so h=d sin (6) make sense?
now [tex] W = -\Delta U[/tex] so if you call your initial position h=0 your final potential is mgh
now can you use d to solve for velocity?
cyspope
27
but how do I find the velocity to maintain 0.25 hp?
661950 = 35v[tex]^{2}[/tex]
v[tex]^{2}[/tex] = 18912
v = 137.524 m/s
this is not what I should get. I need to get 2.6 m/s.
Mindscrape
1,861
This may help you out
[tex]P=\frac{dW}{dt}=\frac{F\cdot ds}{dt} = F \cdot v[/tex]
So you should figure out the force he needs to cancel out gravity, and from there get the velocity. Be careful of units, and it should be a straight shot.
Suggested for: Work problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
