Calculating Kinetic Friction of an 8kg Block
In summary, the 8 kg block is being pulled horizontally on a table by a 6 kg block that hangs in the air by a cord fasten to the 8 kg block over a pulley, there is only friction between the table and the 8 kg block. Both blocks are initially moving with 0,900 m/s and they come to rest after 2 meters. The coefficient of kinetic friction is 0.714.
Swatch
89
A 8 kg block is being pulled horizontally on a table by a 6 kg block that hangs in the air by a cord fasten to the 8 kg block over a pulley, there is only friction between the table and the 8 kg block. Both blocks are initially moving with 0,900 m/s and they come to rest after 2 meters.
I have to use the work-energy theorem to find the coefficient of kinetic friction.
What I've done so far is:
total work done on the 6 kg block must be -0.5*6*0.9*0.9 = 2.43 J
So the net force must be -2.43J/2m = -1,215N
Fy=-mg+T=-1,215 so the tension is 57.58 N
Total work done on the 8 kg block must be -0.5*8*0.9*0.9 = -3.24 J
So the net force on the block must be
Fx=57.58-fk=-3.24J/2m
coefficient of friction must be 55.96/8*9.8=0.714
I don't get the right answer which is 0.786
Could someone please give me a hint to what I am doing wrong.
With thanks in advance
I suggest starting over and thinking in terms of the total change in energy of the system. What's the change in KE? What's the change in PE? The total change in energy must equal the work done by the friction.
I have calculated the total kinetic energy change by using 8+6=14 as the mass and the speeds 0.9 m/s and 0 m/s That energy change is not enough to explain the friction. The book I'm reading has not mentioned potential energy so I am not supposed to use that to solve this. Sorry, I am not any closer to solving this.
book's answer 0.786 correct
reason your approach is not working: you're only accounting for change in kinetic energy, when in fact potential energy is also changing:
friction work = ΔKE + ΔPE
you calculated ΔKE correctly.
you now need ΔPE
fyi, in this case:
ΔPE = mgΔH(8 kg block) + mgΔH(6 kg block)
where ΔH is height change (0 m for 8 kg block, and 2 m for 6 kg block).
you must account for ΔPE to get correct answer
O.K I got it right, including the PE, geosonel. But I don't get why I have to include this energy. I can see that mg*s for the 6 kilo block is the work that is done on that block, but I did already calculate the KE for it, or -0.5*m*v*v. So the friction does work to slow the 6 kilo block down and the 8 kilo. Please explain to me :redface:
Actually, your original method was fine. You just made an error in signs, confusing the direction of the forces.
Realize that the net force is upward. Calling up positive, your force equation should be: T - mg = +1.215. Recalculate the tension accordingly.
Once you use the correct tension, you'll get the right answer.
If you had covered PE, then you could apply the "Work-Energy" theorem using total mechanical energy (KE + PE). I think that way is a bit easier, since the PE automatically takes care of gravity. But no matter, you can solve the problem just like you did, explicitly including the work done by gravity.
Another little trick is to realize that the work done by the tension must be zero. It does positive work on one block, negative work on the other: the total is zero.
Thank you, Doc Al. I understand this now.
Thanks guys.
Doc Al said:
Another little trick is to realize that the work done by the tension must be zero. It does positive work on one block, negative work on the other: the total is zero. (Of course, if you realize that the tension is internal to the system, this will make sense. Only external forces can do net "work" on the system.)
I'm thinking your parenthetic statement is too broad. It would be true of internal forces of a rigid object, or a system with no relative motion between masses (effectively the case in this problem) but does not apply to some cases where there is relative motion, such as inelastic collisions. Sometimes the internal forces are conservative and can be related to a potential energy, but not always.
You are absolutely correct, Dan. Very sloppy of me. :blushing: (I will remove that statement from my earlier post.) Thanks for the correction.
1. What is kinetic friction?
Kinetic friction is the force that opposes the motion of an object when it is in motion against another surface.
2. How is kinetic friction different from static friction?
Kinetic friction occurs when an object is already in motion, while static friction occurs when an object is at rest. Static friction is typically greater than kinetic friction.
3. What factors affect the kinetic friction of an 8kg block?
The kinetic friction of an 8kg block can be affected by the type of surface it is moving on, the weight or mass of the block, and the speed at which it is moving.
4. How do you calculate the kinetic friction of an 8kg block?
To calculate the kinetic friction of an 8kg block, you need to know the coefficient of kinetic friction between the block and the surface it is moving on. This coefficient can be multiplied by the weight of the block to determine the force of kinetic friction.
5. How can the kinetic friction of an 8kg block be reduced?
The kinetic friction of an 8kg block can be reduced by using a lubricant between the block and the surface, decreasing the weight or mass of the block, or increasing the smoothness of the surface it is moving on.
