1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Work Question
  1. Aug 8, 2008 #1
    I am having trouble deciding when to use the work-energy formula; change in KE=W and derivations of this formula, or the Kf+Uf+Eth=Ki+Ui+Wext formula when presented with work problems.
    Are there any type of guidelines or hints that anyone could give me so I can more easily decide which formula to use?
    Thank you.
    Stephen
  3. Aug 8, 2008 #2
    Defennder
    What is Eth and Wext supposed to be here?
  4. Aug 8, 2008 #3
    Eth= thermal energy
    Wext= work done by external surfaces
  5. Aug 8, 2008 #4
    Defennder
    What do "external surfaces" refer to? You meant instead to say "external forces" correct? As a general rule you have look out for keywords in the question to know whether or not you have to take heat loss into account. I'll start with the most inclusive formula, the one you quoted and then read the question to see which factors can be neglected.
  6. Aug 9, 2008 #5
    Redbelly98
    Staff Emeritus
    You can always use
    Kf+Uf+Eth = Ki+Ui+Wext
    With some problems, this becomes
    Kf = Wext
    because all the other terms are zero.
    With some other problems, it becomes
    Kf + Uf = Ki + Ui
    because Eth and Wext are zero.
    You have to read the problem carefully and figure out which terms are zero (if any), then you simplify the equation whenever possible.
  7. Aug 9, 2008 #6
    I was talking in general but an example would be:
    A 5kg box is attached to one end of a spring with a spring constant of 80N/m. The other end of the spring is attached to a wall. Initially the box is at rest at the spring's equillibrium position. A rope with a constant tension of 100N then pulls the box away from the wall. What is the speed of the box after it has moved .5m? The coefficient of friction between the box and floor is .3.
    My professor solved this problem using the formula: Kf + Uf + Delta Eth = Ki + Ui + Wext.
    Wext is the work of the external forces which would be the rope.
    Wext = Tcos theta * Delta r.
    Wext = Tcos0 * .5m = T*0.5m = (100N)*.5m = 50J
    To find the Delta Eth We have to find Wdiss.
    Wdiss = fk *cos theta * Delta r = fk * cos180 * .5m = -fk * .5m = -[tex]\mu[/tex]mg*.5m= -(.3*5kg*9.8m/s/s * .5m)= -7.35J
    And since Delta Eth= - Wdiss, Delta Eth= 7.35J
    Now we can plug data into Kf + Uf + Delta Eth = Ki + Ui + Wext.
    1/2mvf^2 + 1/2kxf^2 + 7.35J = 1/2mvi^2 + 1/2kxi^2 + 50J
    vi=0m/s xi= 0m
    thus
    1/2mvf^2 + 1/2kxf^2 + 7.35J = 50J
    vf=[tex]\sqrt{[2(50J-7.35J-(1/2kxf^2)]/m}[/tex]
    thus
    vf= 3.61m/s
    This was the way my professor did this problem, but couldn't we use the energy-work formula : Delta K=Wc + Wdiss + Wext
    Wdiss = -Delta Eth
    1/2mvf^2 - 1/2mvi^2 = -Delta U +-7.35J + 50J
    where the 50J is the Wdiss and the 7.35J is the Wext that we found earlier.
    1/2mvf^2 - 1/2mvi^2 = (Ui-Uf) + 50J - 7.35J
    And since vi=0m/s, xi=0m and U=1/2kx^2
    1/2mvf^2-0=(1/2k(0)^2)-(1/2kxf^2) +42.65J
    1/2(5kg)vf^2=-(1/2(80N/m)(.5m)^2) + 42.65J
    5/2kg * vf^2= -10J + 42.65J
    2.5kg *vf^2 = 32.65J
    vf^2= 13.06m^2/s^2
    vf=3.61 m/s
    Which is the same answer that my professor got. So, is there any reason why I cannot use the energy-work formula, Delta K=Wc + Wdiss + Wext
    , and W= F*Delta r * cos theta, instead of Kf + Uf + Delta Eth = Ki + Ui + Wext?
    Thank you for all of your replies.
    Stephen
  8. Aug 9, 2008 #7
    Doc Al
    Staff: Mentor
    Assuming that you have the required information, you can use either conservation of energy or the "work-energy" theorem. (Realize that the latter really comes from Newton's 2nd law, analyzing the forces acting on the body, not conservation of energy.)
Have something to add?
Similar Discussions: Work Question
  1. Question on Work (Replies: 4)
  2. Work Question (Replies: 1)
  3. Work question (Replies: 1)
  4. Question on work (Replies: 3)
  5. Work question (Replies: 2)
Loading...
