Work work
  • Thread starter Tastosis
Tastosis
32
A man is pushing a box on top of a plane that is inclined 20 degrees above the horizontal, with a distance of 10 m. The weight of the box is 20 kg and the coefficient of kinetic friction is 0.30. The velocity is constant.
How much force is exerted by the man? Find the work done by force and the work done by gravity.
Summation of forces along x-axis = F - f = 0
Summation of forces along y-axis = n - Wy = 0
f = uk * n
W of Force = Fdcos
W of weight = mgdcos
[PLAIN]http://img96.imageshack.us/img96/4928/17512380.jpg [Broken]
Is my free body diagram correct?
If someone can give a clue on how to get Wy, I think I can solve this. Thanks!
Answers and Replies
PhanthomJay
512
Your first FBD is correct....then you apparently rotated it in your second FBD, which is OK, as long as it doesn't confuse you. You'll need the x and y components of the weight force, which you can find from basic geometry and trig once you realize what is the interior angle in between the Wy and W forces.
Doc Al
Mentor
45,433
1,882
You forgot the x-component of the weight.
See: http://www.physicsclassroom.com/Class/vectors/u3l3e.cfm" [Broken]
Tastosis
32
Wait, what does this mean? What should the summation of forces in the x-axis should be, then?
Doc Al
Mentor
45,433
1,882
Well, when you sum the forces in the x-direction you must include all forces that have an x-component. That includes the weight.
Tastosis
32
So sum of forces in the x-axis is: F - f - Wx?
Now I'm really confused. How do I get Wx and Wy?
Doc Al
Mentor
45,433
1,882
Yes.
Go to the link I gave in post #3.
Tastosis
32
Oh, forgot about the link. Here's what I got....
Wy = mgcos
Wy = 20 kg * 9.8 m/s^2 * cos(20)
Wy = 184.18 N
Wx = mgsin
Wx = 67.04 N
normal force = Wy = 184.18 N
f = uk * n = 0.30 * 184.18 N = 55.25 N
F = f + Wx
F = 55.25 N + 67.04 N
F = 122.29 N
Before I proceed with the work, did I get everything right?
Doc Al
Mentor
45,433
1,882
Looks good to me.
Tastosis
32
Work of force would be = Fdcos
WF = 122.29 N * 10 m * cos 20
WF = 1149.15 J?
Work of weight would be = mgcos? How do I get work of the weight?
Doc Al
Mentor
45,433
1,882
WF = 1149.15 J?
No. In the formula W = Fd cosθ, θ is the angle between the force and the displacement. What's that angle?
Use the same method as above. What's the angle between the displacement and the weight?
Tastosis
32
For force, is the angle 0?
For weight....250? >.<
Doc Al
Mentor
45,433
1,882
Right. The applied force is up the incline and so is the displacement.
For weight....250?
OK. 110° also works.
Tastosis
32
So it's cos 250 or cos 110?
Also, just a quick question, the method on how I got Wx and Wy (in your link):
[URL]http://www.physicsclassroom.com/Class/vectors/u3l3e5.gif[/URL]
Does this only apply to inclined planes and never to horizontal planes?
Thanks!
Doc Al
Mentor
45,433
1,882
Those are equivalent.
It works fine for horizontal planes. (But you shouldn't need it.) If the plane is horizontal, the angle is 0.
Suggested for: Work work
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
