Working on a Difficult Integral
  • Thread starter Zoran
  • Tags
    Integral
In summary: These integrals can be solved using the substitution u = sin(x) and v = sin(y). This will result in:\int_{\frac{\pi}{4}}^{\frac{\pi}{2}} dx * \int_{\frac{\pi}{4}}^{\frac{\pi}{2}}
Zoran
Hi All: I am working on a research project and am trying to get a symbolic solution to the following integral:
[tex]\int_{0}^{\frac{\pi }{4}}\int_{0}^{\frac{\pi }{4}}\frac{\cos\left ( z_{1} \right )\cos \left ( z_{2} \right )}{\sqrt{\left ( \cos\left ( z_{1} \right ) ^{2}+\frac{1}{2} \right )\left ( \cos\left ( z_{2} \right ) ^{2}+\frac{1}{2} \right )-\frac{1}{4}}}dz_{1}dz_{2}[/tex]
The problem seems to be with the inclusion of the -1/4 in the denominator i.e. without it the integral has the solution:
[tex]\arctan\left ( \frac{1}{\sqrt{2}} \right ) ^{2}[/tex]
Any help is appreciated.
Hello! Thank you for sharing your research project with us. I understand that you are trying to find a symbolic solution to the integral with the added -1/4 in the denominator. This can certainly be a challenging task, but I will try my best to provide some guidance.
Firstly, let's break down the integral into two separate integrals, one for each variable z1 and z2. This will make it easier to handle the complex denominator. We can also use the trigonometric identity cos^2(x) = 1/2 + 1/2cos(2x) to simplify the denominator.
So, our integral becomes:
\int_{0}^{\frac{\pi }{4}} \frac{\cos(z_{1})}{\sqrt{\left ( \frac{1}{2}+\frac{1}{2}\cos(2z_{1}) \right )\left ( \cos(z_{2})^{2}+\frac{1}{2} \right )-\frac{1}{4}}} dz_{1} * \int_{0}^{\frac{\pi }{4}} \frac{\cos(z_{2})}{\sqrt{\left ( \frac{1}{2}+\frac{1}{2}\cos(2z_{2}) \right )\left ( \cos(z_{1})^{2}+\frac{1}{2} \right )-\frac{1}{4}}} dz_{2}
Now, we can use the substitution u = cos(z1) and v = cos(z2) to simplify the integrals further. This will result in:
\int_{\frac{\sqrt{2}}{2}}^{1} \frac{du}{\sqrt{\left ( \frac{1}{2}+\frac{1}{2}u^{2} \right )\left ( v^{2}+\frac{1}{2} \right )-\frac{1}{4}}} * \int_{\frac{\sqrt{2}}{2}}^{1} \frac{dv}{\sqrt{\left ( \frac{1}{2}+\frac{1}{2}v^{2} \right )\left ( u^{2}+\frac{1}{2} \right )-\frac{1}{4}}}
Now, we can use a partial fraction decomposition to separate the fractions in the denominators. This will
1. What is a difficult integral?
A difficult integral is a mathematical expression that cannot be solved using standard integration techniques. It often involves complex functions, multiple variables, or special functions that do not have a closed form solution.
2. How do you approach a difficult integral?
There is no one set approach to solving a difficult integral, as each problem may require a different method. However, some common strategies include using substitution, integration by parts, or breaking the integral into smaller, more manageable parts.
3. What are some tips for working on a difficult integral?
Some tips for working on a difficult integral include carefully studying the problem and identifying any patterns or special properties, trying different integration techniques, and utilizing online resources or consulting with other mathematicians for guidance.
4. Can a difficult integral always be solved?
No, not all difficult integrals can be solved. Some may require advanced mathematical techniques or even computer software to find an approximate solution. In some cases, the integral may be unsolvable and have no closed form solution.
5. How can solving difficult integrals be useful in scientific research?
Solving difficult integrals is essential in many scientific fields, such as physics, engineering, and economics, as it allows for the calculation of important quantities and the analysis of complex systems. It also helps in developing new mathematical techniques and understanding the underlying principles behind these difficult integrals.
  • Calculus
  • Topology and Analysis
