Working on Triple Integral
  • Thread starter violette
violette
Hi everyone, I have problems solving triple integral question like this:
Find the volume of the solid bounded below by the cone [itex]\varphi[/itex]=[itex]\frac{\pi}{6}[/itex] and above by the plane z=a.
I can do simple triple integration questions,but can some please give me some guidance on how to solve triple integrals which requires us to convert to other coordinates(spherical,cartesian)?I have problems finding the new limits after I convert.
Appreciate any help and guidance.Thanks in advance!
Answers and Replies
Zahar
My opinion :
It seems for me that the other bounds is z = 0, maybe I do not understand but mentioned bounds is not quite enough for finite volume of the body.
I like Serena
MHB
16,344
248
Welcome to PF, violette! :smile:
The coordinates you're looking for are cylinder coordinates (r, theta, z).
What do you think the limits are for z?
What would r on the cone be for a specific z?
Zahar
I think maybe something like this, but do not sure
For any z the cone has a distinct radius of the cross-section, then R ( z ) = z * tg ( pi/6 )
A) cartesian system:
Integral_z ( from 0 to a )
{ Integral_x ( from 0 to z*tg( pi/6 ) )
{ Integral_y ( from 0 to sqrt[ (z*tg( pi/6 ) )^2 - x^2 ] )
4*dydxdz
B) cylindrical system:
{ Integral_angle ( from 0 to 2*pi )
{ Integral_R ( from 0 to z*tg( pi/6 ) )
R*(dz)*(d angle)*(d R)
C) The volume of a cone ( 1/3 )*H*pi*R^2 = ( 1/3 )*a*pi*(a*tg( pi/6 ))^2 = 22.34
violette
Hi thanks for the replies =)
but may I know why do we need to change it to cylindrical coords?I thought spherical would be better?
for my spherical coords, i got:
0 ≤ z ≤ a
0 ≤ θ ≤ 2∏
0 ≤ ρ ≤ (2a)/√3
can i also ask,is θ always between 0 and 2∏?How do we determine whether it is or not?
thanks!!
I like Serena
MHB
16,344
248
0 ≤ z ≤ a
0 ≤ θ ≤ 2∏
0 ≤ ρ ≤ (2a)/√3
thanks!!
Your z and θ are right! :smile:
But I'm afraid your ρ is not quite right.
As you have it now, it is a constant, meaning you're describing a cylinder.
But it is supposed to be a cone.
ρ should be dependent on z.
And what you have there is cylindrical! ;)
Cylindrical is polar with an added z coordinate.
Just like polar, the range of θ is 0 to 2∏.
In spherical you have 2 angle θ and φ.
That works like longitude and latitude on earth.
One goes all the way around (longitude), and the other has range of 0 to ∏ (compare to latitude).
violette
Ah I see,so for cone, ρ will be in terms of z all the time?
I like Serena
MHB
16,344
248
Yes!
Btw, I see that you have multiplied by 2/√3.
How is your phi defined?
However it is, this is not the right multiplier.
violette
Why is that so?
cosine [itex]\frac{\pi}{6}[/itex]=[itex]\frac{\sqrt{3}}{2}[/itex],hence my [itex]\rho[/itex] is 2/[itex]\sqrt{3}[/itex]z?
I like Serena
MHB
16,344
248
Why is that so?
The cosine gives the ratio with the hypotenuse, but that one doesn't play.
z and ρ are aligned with the adjacent and the opposite sides.
violette
oh no,sorry i think i did it wrongly.
Im trying to convert to spherical coordinates.
0 ≤ θ ≤ 2[itex]\pi[/itex]
0 ≤ ρ ≤ [itex]\frac{2a}{\sqrt{3}}[/itex]
0 ≤ [itex]\phi[/itex] ≤ [itex]\frac{\pi}{6}[/itex]
Does it look right now?
I like Serena
MHB
16,344
248
Oh, okay, then the multiplier is good and the ranges too!
But... :uhh: spherically the bottom (top?) of the cone would be part of the sphere (round).
But your problem says it's a plane at z=a... :confused:
violette
oh man!u mean to use spherical coordinates,the surface has to be round?!
i never knew that =S
I like Serena
MHB
16,344
248
Well, at ρ=constant, you're tracing a sphere.
Actually, you can trace a plane with a ρ that depends on φ:
[tex]\rho = {a \over \cos \phi}[/tex]
But to integrate that tends to get ugly! :yuck:
violette
Ah I see..thanks so much =D
GENHEN
I have a similar problem, where you have to find the area cut between the cylinder x^2+y^2≤1 and 0≤ρ≤a, im so lost its not even funny. I think we are supposed to use spherical to get ρ as variable to a, and 0 ≤ θ ≤ 2π, and 0 ≤ ϕ ≤ (the intersection of sphere and cylinder), and thats all ive got right now, this setup seems to stem from actual constants, but it does not make logical sense how to make ρ change from the edge of the cylinder to a. Should I repost this on another thread? Or can you guys maybe help me?
mpg
$\lim$
I like Serena
MHB
16,344
248
Welcome to PF, GENHEN! :smile:
It seems okay to use spherical.
In your case you should still use the full range 0 ≤ ϕ ≤ π.
But your ρ should depend on ϕ.
[tex]\rho = \left[\begin{matrix}
a, & \text{ if } \sin \phi < {1\over a}, \\
{1 \over \sin \phi}, & \text{ otherwise}.
\end{matrix}\right.[/tex]
Suggested for: Working on Triple Integral
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
