- #36
zoobyshoe
- 6,510
- 1,290
No, metal cutting is a shearing process.Gokul43201 said:Metal cutting is typically an abrasion based process
It's certainly doable, it's just frickin' hard. Back in the day, people were good at it, and had all the tricks down. Certainly you have to hold the piece in a massive, rock solid vise. As you chisel along the chip curls up in front of the chisel. Depending on the depth of the cut, each hammer blow may only advance the chisel 1/8 inch or so. The chisels have to be resharpened constantly, and they wear out fast, but back then, they made all their own right there in the shop. There is, no doubt, a set of specific angles at which to grind the chisels for various kinds of cuts.I'll accept it's doable if someone tells me they've actually done it.
They were, for the most part, probably not working steel, but soft iron, probably softer than today's hot rolled steel, which is the softest common steel. In all cases, chiseling produced the rough cut. Finishing had to be done with scrapers and files.
I may hunt up a link if I get amitious. I researched all this machine shop history back when I was in school because it occurred to me that you're always copying the straight lines and flat planes built into the machine tool to the part you're making. That made me wonder how they arrived at the first straight line, or the first flat surface. It took me about three months to find out how it was done. (The web didn't exist back then.) (Edit: I mean back then when I was doing this research.)
