How to Incorporate Metric Coefficients into Worldline Plots in Curved Spacetime?
In summary: PhDThesis/Schwarzschild_Thesis.pdfIn summary, the three leg lengths would be limited to differentials? But how would the metric coefficients be incorporated into those leg lengths? It seems like the leg differential lengths would have to vary inversely with the magnitudes of the metric coefficients?
exmarine
241
TL;DR Summary
How does one plot the world-lines for curved spacetime? That is such a useful tool for fixing the concepts for the Minkowski case that I would like to also use it to understand other cases.
Since it is nonlinear, the 3 leg lengths would be limited to differentials?
It seems like the leg differential lengths would have to vary inversely with the magnitudes of the metric coefficients? For example, near the horizon for the Schwarzschild case as the g_tt coefficient approaches zero, the component time differentials get very long as the proper clock slows down and counts fewer seconds? The radial differentials would get very short as g_rr gets very large and even light cannot get away?
Thanks.
It depends which coordinate system you choose to use and how you choose to represent those coordinates. See the plethora of methodologies for drawing maps of the Earth - this problem is analogous.
That said, if you've got a symmetric spacetime you can often suppress a dimension or two and come up with something. Kruskal diagrams are a good map around Schwarzschild black holes, and Penrose diagrams are more abstract but can be drawn for more spacetimes.
Likes exmarine and vanhees71
Check out
https://www.spacetimetravel.org/sectormodels1/sectormodels1.html
I met these researchers at a conference last year. I’m looking into whether my light-clock diamonds can be incorporated into these sector models.
In the simplest curved cases, you could look at the de Sitter spacetimes using hyperboloids. My students were studying the clock effect on them.
Likes exmarine and Ibix
Consider the curved surface of the earth. You can represent it on a flat plane with a map, but it won't be a map to scale.
The mathematical process of drawing maps of the curved surface of the Earth on a flat piece of paper is known as projection. There are several widely used schemes, for example Mercator projection.
If you use a globe, rather than a flat piece of paper, though, you can draw a map of the Earth on the surface of the globe (i.e. on a sphere) that is to scale.
Equivalently, there is no difficulty in drawing a space-time diagram in a curved space-time on a flat piece of paper. But it won't be to scale.
A certain amount of insight into GR can be gained by drawing space-time diagrams on curved surfaces, such as the sphere, though the technique is limited. I believe it is not generally possible to crate a curved 3d surface to draw a 2d space-time graph on for a general 1+1 space-time geometry "to scale", but certain special cases can be illustrated that way.
The metric of GR can be thought of as a tool to get actual distances and times from the distored map imposed on a curved space-time by a particular choice of coordinates.
For an example, @exmarine might want to take a look at Flamm's parabaloid (Google finds some good links, including the wikipedia article on the Schwarzschild spacetime).
Likes exmarine
Look, world lines for SR drawn on paper using Minkowski coordinates already need to be interpreted using the metric. Visually longer intervals often have shorter invariant interval. There is really no difference for arbitrary world line in arbitrary coordinates for an arbitrary metric. You can just place orthogonal axes on a flat plane (even if the actual coordinates are not 4-orthogonal), draw world lines, then compute (using the metric expressed in said coordinates) where to place marks for proper time. For qualitative understanding, it is often useful to draw light cones, which can be read from any metric at any point trivially by setting the line element to zero.
Likes pervect, exmarine and Nugatory
Check out the articles by Rickard Jonsson (the two theses at the very bottom provide a good overview):
http://www.relativitet.se/articles.html
Likes exmarine
1. How do metric coefficients affect worldline plots in curved spacetime?
Metric coefficients are used to calculate the length and curvature of spacetime. They are essential in understanding the behavior of particles and objects in curved spacetime, which is depicted in worldline plots.
2. What is the process for incorporating metric coefficients into worldline plots?
The process involves first determining the metric tensor for the given curved spacetime, which describes the relationship between space and time. Then, the metric coefficients can be calculated from the metric tensor and used to plot the worldlines of particles in the curved spacetime.
3. How do metric coefficients affect the shape of worldline plots?
Metric coefficients directly affect the curvature of spacetime, which in turn affects the shape of worldline plots. A higher curvature will result in a more curved worldline, while a lower curvature will result in a flatter worldline.
4. Can metric coefficients be incorporated into worldline plots in flat spacetime?
Yes, metric coefficients can still be used in worldline plots in flat spacetime. While the curvature may be zero, the metric coefficients can still be calculated and used to accurately depict the behavior of particles and objects in the flat spacetime.
5. Are there any limitations to incorporating metric coefficients into worldline plots?
One limitation is that the calculations and incorporation of metric coefficients can become complex and time-consuming in highly curved spacetimes. Additionally, the accuracy of the plots may be affected by any errors in the calculation of the metric coefficients.
20K
