- 1
Dear all,
I am trying to build single axis solar tracker using worm gear, I need guide line for calculation of worm gear & stepper motor .he are some relation i taken, But i wanted whether its correct & need to explain with example
efficiency= (output Power of Worm gear/ Input Power of WormGear) = Po/Pinput
Output power =P0=(2*pi*Outputspeed*outputtorque)/60
Output power in Kw
Output speed in rev/min
output torque in Nm
Input power = Pinput=(2*pi*Input speed*Input torque)/60
Input power in Kw
Input speed in rev/min
Input torque in Nm
Net Torque= Toutput+TInput+Tholding =0
These are basic equation followed usually
In order to drive 250Kw plant ; assume 15kw per row I have 16 rows with 1 column.
Worm gear has to Drive 16 rows with coupling with single column item
each panel weighs 20Kg ; 60 panel per row-> 60*20kg=1200Kg
Each row structural weight around = 700Kg
Net weight alone = 1900Kg per Row
so load on worm gear might be 1900*16=30400
worm gear relation part:
if torque(high) gear ratio(high) speed o/p(LOW) vice versa
There are lot of parameter in case of worm gear which are given below as example:
1 st Stage Ratio of Worm Gear: 1/10
2 nd Stage Ratio of Worm Gear:1/73
Rated Output Speed: 0.078rpm
Rated Output torque: 910 Nm
output torque :1300Nm
holding torque :10.4Knmt
axila load : 133KN
radial load :53KN
o/p speed : 56.9rpm
In case of motor i consider the motor as
https://www.anaheimautomation.com/products/stepper/stepper-motor-item.php?sID=24&pt=i&tID=75&cID=19
how can use these sample for calculation. can some help me out here.
Output power in Kw
output torque in Nm
Input power in Kw
Input torque in Nm
axila load : 133KN
radial load :53KN
o/p speed : 56.9rpm
