- #26
- 4
- 1
Oh, yeah - and what's the worst they behave like having 10 PhDs in physics and engineering. :yuck:FredGarvin said:All of those geeks that spent time making up "the science behind Star Wars/Star Trek" are dolts.
On the contrary - you will explode if you hold your breath. Not literally, but your lungs will rupture internally and you will have a 100% mortality rate within 20 minutes.Janus said:Actually, the movie got this right. The human body can survive exposure to vacuum for up to about 30 sec without any ill effects. You will not explode, nor will your blood boil, etc.
Star Wars is exempt. It is not, nor has it ever claimed to be, science fiction. It is fantasy. By definition, it is exempt from adherance to plausible physics (as much as Lord of the Rings is, for example).Mozart said:A popular one would be sound in space which Star Wars is famous for, among other movies.
That would only happen if you were breathing a regular air mix. Astronauts usually breathe 3 lbs PSI pure oxygen in their suits. ( the Shuttle itself has a normal atmosphere, but this is why an astronaut has to go on pure oxygen for two hrs before going EVA. This flushes the nitrogen out of his blood, and it is the nitrogen coming out of solution in the blood that causes the bends.)Pengwuino said:Wouldn't you get the bends?
I would expect that Dave Bowman was breathing regular air. It's a very long-term voyage.Janus said:That would only happen if you were breathing a regular air mix. Astronauts usually breathe 3 lbs PSI pure oxygen in their suits. ( the Shuttle itself has a normal atmosphere, but this is why an astronaut has to go on pure oxygen for two hrs before going EVA. This flushes the nitrogen out of his blood, and it is the nitrogen coming out of solution in the blood that causes the bends.)
Yes, if you hold your breath. But you won't undergo the type of explosive decompression some people expect.DaveC426913 said:On the contrary - you will explode if you hold your breath. Not literally, but your lungs will rupture internally and you will have a 100% mortality rate within 20 minutes.
This is how many scuba divers die, and that's just going from 2 atmospheres to 1, not 1 to 0.
This has to be one of the worst ideas ever. The human brain does not magically produce energy, it uses energy from food. If the aliens were feeding the humans slime, they would have got more energy by just burning the slime, rather than putting so much energy into building and maintaining human body tissues. I guess you're just not supposed to think about it too hard.loseyourname said:In The Matrix, why don't the machines simply harvest a non-human animal for energy, something that processes food more efficiently, produces more energy, and wouldn't stage revolts due to their freedom of choice?
What keeps blood from boiling when the external pressure is less than its vapor pressure?Janus said:Actually, the movie got this right. The human body can survive exposure to vacuum for up to about 30 sec without any ill effects. You will not explode, nor will your blood boil, etc.
Well its possible since LA enacted that "Anti-lava building code" into law. :tongue2:matthyaouw said:LA (the volcano film) has to be one of the least scientific ever. Since when did lava travel neatly down streets, rather than through anything and everything. I won't even begin to talk about the tectonic setting of LA.
He had a drag chute under the F/A-18's speed brake... the speed brake works, but there's no parachute under it, not even room for one. I recall some AIr Force fighters had drag chutes as late as twenty-five years ago.Mozart said:Its been a long time since I've seen that movie. I do remember seeing Will Smith with a parachute though. I believe he was flying an f/a-18 hornet which can be equipped with ejection seats. Or was it that the parachute actually came out of the back of the aircraft, because I've never seen or heard of that in actual fighters.
Its because the blood is still contained in the circulatory system which keeps the pressure inside the body high enough that the blood can't expand.LeonhardEuler said:What keeps blood from boiling when the external pressure is less than its vapor pressure?
