Homework Help: Write Differential Eq ?
  1. Jun 25, 2012 #1
    Hi ,
    Can anyone help me on this problem please?!
    Answer is given but i want to know steps to come to it, i think i tried a lot to solve it but i couldnt come to the given result.
    Thanks to all
  3. Jun 26, 2012 #2
    tiny-tim
    hi xmenus! welcome to pf! :wink:
    show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
  4. Jun 26, 2012 #3
    Here's the link of doc..I think i tried loop method and many other forms but.... here i just showed the analogy i tried but i couldnt come to the result.(First circuit is different one)
    I took an other example just to show or ask if the other circuit can be solved with the same analogy?!
    https://www.dropbox.com/sh/7g4vmpl4uhjbyl4/wwNdGrKm5o
  5. Jun 26, 2012 #4
    tiny-tim
    it's rather difficult to read :redface:
    anyway, what is D ? :confused:
  6. Jun 26, 2012 #5
    psparky
    That's a tough circuit you posted for finding a differential equation.
    Don't know for sure....but perhaps a node analysis on the upper right hand node? Current in equal current out sorta thing.
    Using SL and 1/(SC) may simplify things as well.
  7. Jun 26, 2012 #6
  8. Jun 26, 2012 #7
    tiny-tim
    ah, D = d/dt !
    ok, you've replaced C and R3 (in series) by an impedance Z1
    (btw, wouldn't Z3 be an easier name to keep track of? :wink:)
    then you've replaced R2 and Z1 (in parallel) by Ze
    but then you've stopped (presumably you're going to replace L and Ze, then replace that and R1?)
    well, that looks fine so far :smile:
    what's the difficulty?​
  9. Jun 26, 2012 #8
    The problem is that it's not working like that.I cant come to the result, i dont know!?
  10. Jun 26, 2012 #9
    tiny-tim
    but you stopped, you only got as far as Ze :confused:
  11. Jun 26, 2012 #10
    No,actually i worked on it till to the end but the result i got is not like the given one.
    You are right, i didnt post other steps,but on that way it didnt work!
  12. Jun 26, 2012 #11
    tiny-tim
    we can't comment on why it didn't work unless you show us what you did
  13. Jun 26, 2012 #12
    Finally,after many attempts, i solved it :D !
    I might post the solution so anyone can find it useful maybe.
    Thank you a lot anyway,and thank for your time!
  14. Jun 26, 2012 #13
    Solution is in .pdf file.
    Regards
