Writing to text file in Win Spice
  1. May 18, 2010 #1
    Hi,
    I'm trying to create an IV plot of a device by varying the resistance of a resistor and measuring the current through it and voltage drop across it. I'm using WinSpice to do this. I would like to write the values to a text file as I seep through the resistance of the resistor. I've tried to write some code shown below:
    .control
    let res = 1
    while res <= 1000
    alter @rload[resistance] = res
    op
    write output.txt v(1) i(vmeas)
    let res = res + 50
    end
    .endc
    This doesn't work because it keeps overwriting the output file and I only get the last calculated values of current and voltage. I need a command to append the file instead of overwriting it.
    Any help or suggestions or sample code would be much appreciated.
    Alexander
Draft saved Draft deleted
