X = 54*5.51-9.8*5.51(squared)
NINHARDCOREFAN
118
For problem 11(please see the pdf file), I did this:
0 = 54 - 10t
t=5.51
x = 54*5.51-9.8*5.51(squared)
x = 148.8
What did I do wrong?
Note:
V= Vi + GT
X= Xi + Vi*T+.5*G*T(squared)
  • hw.pdf
Answers and Replies
NINHARDCOREFAN
118
Mistake
I meant 0 = 54-9.8T
enigma
Staff Emeritus
Always keep your units in your calculations. It makes it easier to troubleshoot.
0 = 54 - 10t
t=5.51
Initial velocity is not 54 m/s, but it washes out in this part, because you know both velocities and can subtract them.
x = 54*5.51-XXX*9.8*5.512
x = 148.8
The initial velocity does not wash in this equation, and you missed a 1/2 term in the acceleration portion.
NINHARDCOREFAN
118
yeah, .5*108=54. I didn't forget the 1/2. I don't understand when you say, you have to subract both velocities, because if you do that you get the same velocity
enigma
Staff Emeritus
V= Vi + GT
X= Xi + Vi*T+.5*G*T2
0 = 54 - 10t
t=5.51
x = 54*5.51-9.8*5.512
Look again, carefully NIN.
54m/s = 108m/s - 9.8m/s2*t
The two like terms can be subtracted, giving you what you got for the first line.
0 = 54m/s - 9.8m/s2*t
That doesn't mean that the initial velocity is now 54m/s.
For the second line, the 1/2 term is not on the velocity portion, it's on the acceleration portion!
x = 0m + (108m/s * 5.51s) + (1/2 * 9.8m/s2 * t2)
NINHARDCOREFAN
118
<i>The initial velocity does not wash in this equation, and you missed a 1/2 term in the acceleration portion.</i>
so I just use the original velocity? I meant to put 1/2 in the equation, it was a typo.
enigma
Staff Emeritus
Yep, that's it.
If you think to calculus, the x= equation is merely the integral of the first equation. Since the Vi term is a constant, it just gets a t added to it, but it doesn't change itself.
NINHARDCOREFAN
118
Thanks a lot.
NINHARDCOREFAN
118
Another question, for problem 13(please see the pdf file) what do i do? I'm getting 0 as an answer
21.6(squared)= 16.2m/s(squared)-2*9.8m/s(x-10.4m)
HallsofIvy
43,021
970
The stone will go up as long as it's velocity is positive, come down when it's velocity is negative. It will be at it's highest point when it's velocity is 0.
Solve your velocity equation (that you got earlier) equal to 0 to find t when that happens, then plug that t into your height function.
Since velocity is the derivative of height, this is the same as the more general calculus rule: to find max or min of a function, set it's derivative equal to 0.
Suggested for: X = 54*5.51-9.8*5.51(squared)
  • Last Post
  • Last Post
  • Last Post
