X an y components of a vector
  • Thread starter jpd5184
what are the x and y components of a vector a in the xy plane if its direction is 210(degrees) counterclockwise from the positive direction of the x axis and its magnitude is 14 m.
vector is in the third quadrant with an angle of 30(degrees)
i got the angle to be 30(degrees) so i just did
14sin30 for the x component = 7.0
14cos30 for the y component = 12.1
should they both be negative since there in the third quadrant or do the negatives cancel to get a positive.
Answers and Replies
Char. Limit
Negatives cancel only when you multiply them. Since you aren't multiplying here, both parts are negative.
would my answers be correct then
x = -7.0
y= -12.1
Char. Limit
That seems right, yes.
Although, if significant figures were important, the y component might have to be rounded... I'm not sure how important they are here.
14.cos 30=x . if it is 30 degree to x (210), x have to be bigger than y. (to correct)
well if its 210(degrees) counterclockwise then wouldnt the angle be 30(degrees) sin 210-180 = 30 degrees
why would x be cos and not y. if the vector is in the third quadrant and cos is adjacent/hypotenuse then adjacent would be x so the only side left would be y which you would be solving for.
anybody please
Char. Limit
I'm not sure what you mean...
If you mean that the x component should correspond to the cosine, this is because the cosine of the angle measures the length of the adjacent side to the angle, in this case, the x-axis.
ok i got it thanks.
14cos30 = -12.1 x-component
14sin30 = -7.0 y-component
Related Threads on X an y components of a vector
23K
  • Last Post
31K
  • Last Post
10K
9K
12K
