X'=cos(x+t) solve for x
  • Thread starter niceperson
In summary, the equation X'=cos(x+t) represents the derivative of a function with a cosine term involving variables x and a constant t. To solve for x, separation of variables can be used and the possible values of x can range from negative to positive infinity. The value of t determines the starting point of the cosine function and this equation has applications in modeling oscillating systems and analyzing waves and vibrations in fields such as engineering and physics.
niceperson
solve the differential eqn: dx/dt=cos(x+t)
x'=cos(x+t)=cosxcost-sinxsint
let z=sinx, dz/dx=cosx
dz/dt=(dz/dx).(dx/dt)=cosx(dx/dt)
however this substitution quickly fails
any ideas?
thanksx
Try something simpler. Hint: You don't need to expand cos(x+t).
Used z=x+t
get: int(1/(cosz+1)=in(t) on separation of the variables.
cheers
Can you finish the problem now?
What is the equation X'=cos(x+t)?
The equation X'=cos(x+t) represents the derivative of a function that has a cosine term with a variable x and a constant t.
How do you solve for x in X'=cos(x+t)?
To solve for x, you can use separation of variables by rearranging the equation to have all x terms on one side and all t terms on the other side. Then, you can integrate both sides to solve for x.
What are the possible values of x in X'=cos(x+t)?
The values of x can range from negative infinity to positive infinity. However, it may be more useful to find the values of x within a specific range that is relevant to the problem at hand.
What is the relationship between x and t in X'=cos(x+t)?
The value of t will determine the starting point of the cosine function in relation to the x-axis. As t increases, the starting point will shift to the left, and as t decreases, the starting point will shift to the right.
What are some real-world applications of X'=cos(x+t)?
This type of equation can be used to model oscillating systems, such as the motion of a pendulum or a mass-spring system. It can also be used in fields such as engineering and physics to analyze the behavior of waves and vibrations.
