X in dA => x isolated or strict limit (Topological space)
In summary, if x is not isolated, then it is a strict limit point of A if and only if there is a sequence that converges to x. However, this proof does not work if there are an uncountable number of open sets.
NickAlger
I am trying to show the following proposition, but I can only do so in the special case where the basis for the topology is countable. I posted this in the calc & analysis forum and didn't get any responses - I think that this is a more appropriate forum judging by the other posts.
Proposition. If x is in [tex]\partial A[/tex], then x is either an isolated point, or a strict limit point of both [tex]A[/tex] and [tex]A ^{c}[/tex]. ([tex]A[/tex] is a set in a topological space, [tex]\partial A[/tex] is the boundary)
So far, my reasoning is this. Suppose x is not isolated - then let's show that it is a strict limit point of [tex]A[/tex] by constructing a sequence [tex]\left\{ x_{n}\right\}[/tex] in [tex]A[/tex] that converges to x.
If the number of open sets containing x were countable, [tex]\left\{ E_{1}, E_{2}, E_{3}, ... \right\}[/tex], then I would put [tex]x_{1} \in \left(A \cap E_{1}\right) \backslash\left\{x\right\}[/tex], [tex]x_{2} \in \left(A \cap E_{1}\cap E_{2}\right) \backslash\left\{x\right\}[/tex], [tex]x_{3} \in \left(A \cap E_{1}\cap E_{2}\cap E_{3}\right)\backslash\left\{x\right\}[/tex], and so forth.
We know these intersections can't be empty - if [tex]E_{i}[/tex] and [tex]E_{j}[/tex] are open and contain x, then [tex]E_{i}\cap E_{j}[/tex] is also an open set containing x. Since x is not isolated, [tex]E_{i}\cap E_{j}[/tex] must contain some [tex]y \in A[/tex] distinct from x. Thus for a countable number of open sets containing x, we can construct the proper convergent sequence to prove the result.
However, this logic will not work if there are an uncountable number of open sets. I could extend my argument if only the basis is countable, but not to a topology without a countable basis.
Why are you restricting yourself to sequences? There is nothing in the definition of a limit point requiring that it be a sequential limit. In fact, a point x is a limit point of A iff you can construct a net in A\{x} that converges to x.
I'm not really sure what a net is, though from a quick googling it seems to be a generalization of a sequence, so I will look into it.
However, the http://www.ma.utexas.edu/~arbogast/driver.pdf" I'm working from (which could be wrong...) defines a strict limit as follows (page 9),
Definition. A point [tex]x \in \partial A[/tex] is a strict limit point of [tex]A \subset X[/tex] if there is a sequence [tex]\left\{x_{n}\right\}\subset A \backslash \left\{x\right\}[/tex] such that [tex]lim_{n\rightarrow \infty}x_{n}=x[/tex].
If the book is wrong and you need a net to prove the proposition, I would be interested in finding a counterexample for it as currently written.
Ok, I think I might have a counterexample to it as written, but I'm not totally convinced and need to mull it over a bit. Let me run it by yall.
Let Y be a uncountable set and let [tex]\Re[/tex] be the the real line. Construct a basis for the topology of the combined sets as follows: 1) All singleton points in Y are in the basis. 2) The standard metric basis for [tex]\Re[/tex] is in the basis.
Basically we are joining a set with the discrete topology together with the real line. I think this works. Edit: no it doesnt
Now, if [tex]J[/tex] is the interval [tex]\left( -\infty,1\right)[/tex], then [tex]\overline{J}[/tex] is still [tex]\left( -\infty,1\right][/tex] (?), and [tex]\overline{J_{c}}[/tex] is [tex]Y \cup \left[1,\infty\right)[/tex]. Thus [tex]\partial J[/tex] is [tex]\left\{1\right\}[/tex], which is not an isolated point.
Consider the uncountable number of open sets [tex]\left\{1, y\right\}[/tex] Edit: These actually aren't open )-: for all points [tex]y \in Y[/tex]. These all intersect each other only at the single point 1, so there is no way you could construct a sequence that would get them all.
(Edit: changed from [0,1) to all reals.)
Edit2: Wait actually there is a problem with this counterexample, it doesn't work.
How about [itex][0, \omega_1][/itex], where [itex]\omega_1[/itex] is the first uncountable ordinal? [itex]\omega_1[/itex] is in the boundary of of [itex][0, \omega_1)[/itex]. However, it's not an isolated point (it's a limit ordinal), and it's not the limit of any sequence coming out of [itex][0, \omega_1)[/itex] (easy to prove).
I'm not sure you mean by [tex][0, \omega_1)[/tex]. Could you elaborate?
Are you familiar with order topologies? [itex][0, \omega_1)[/itex] denotes the set of all ordinals strictly less than [itex]\omega_1[/itex].
I am new to topology and have not read about that yet. I'll look into it, thanks.
So far my search for counterexamples has been mostly with variations on discrete topologies, I think I am close to coming up with an example of my own that works, so I'm going to keep thinking about my own ideas for a bit.
I think I managed to come up with another example that doesn't involve ordinals or anything exotic. I can give you a hint if you want.
Thanks, but not right now. Maybe in a day or so if my current strategy doesn't pan out.
Heh, my counterexample has somehow managed to morph into something basically equivalent to [0,w1). I'd be interested in hearing a hint about the other example you mention.
Try the cocountable topology on R, i.e. the topology whose proper closed sets are precisely the countable subsets of R.
1. What is the definition of an isolated point in a topological space?
An isolated point in a topological space is a point that has a neighborhood that does not contain any other points of the space. In other words, it is a point that is not a limit point of any subset of the space.
2. How does a topological space differ from a metric space?
A topological space is a set of points with a defined set of open sets, while a metric space is a set of points with a defined metric or distance function. In a topological space, the open sets determine the topology of the space, while in a metric space, the metric determines the topology.
3. What is a strict limit in a topological space?
A strict limit in a topological space is a point that is a limit point of every subset of the space. In other words, every neighborhood of the point contains infinitely many points of the space.
4. How are isolated points and strict limits related in a topological space?
In a topological space, an isolated point is not a strict limit, as it has a neighborhood that does not contain any other points. However, a strict limit can still be an isolated point if it is the only point in its neighborhood.
5. What are some real-life applications of topological spaces and strict limits?
Topological spaces and strict limits have applications in various fields such as physics, computer science, and economics. In physics, they are used to study the behavior of particles and the structure of space-time. In computer science, they are used in algorithms for data analysis and machine learning. In economics, they are used to model market behaviors and optimize resource allocation.
  • Linear and Abstract Algebra
