Understanding the Interaction of X-Rays & Electrons
In summary: Thanks for asking! In summary, the x-ray photons have a short wavelength and are very energetic, which is why they only absorb/emit electrons at the lower energy levels.
jdstokes
523
Hi all,
I got asked a question recently which I really should know but wasn't able to answer to my satisfaction.
When an x-ray is emitted by an ionizing process, typically an inner electron is ejected and an electron from a higher orbit ``falls'' into its place. In the process an x-ray is emitted of energy equal to the difference between the initial and final states.
The thing I wasn't able to explain is why the incoming x-ray/electron preferentially interacts with the inner (core) electron rather than the outer electrons. Surely the outer electrons are more susceptible to ejection since less work is required to bring them to infinity, and yet it seems in most cases that the incoming photon will interact with the core electron which is shielded by the outer electrons.
Can anyone help me understand this and hopefully point me in the direction of a suitable reference?
Thanks,
James
Science news on Phys.org
Hi James,
I've replied to something similar on a related thread in the Homework Forums [it was a multiple choice question]
question said:
Quantum transitions that result in the characteristic sharp lines of the X ray spectrum always involve;
a. the inner electron shells
b. electron energy levels that have the same principal quantum number
c. emission of beta particles from the nucleus
d. neutrons within the nucleus
e. protons within the nucleus
Poster's Answer said:
I put (b) for this answer because I thought the energy levels were related to the wavelength of the absorbed/emitted photons and spectrums depend on wavelength of radiation? Correct answer is (A)
Hootenanny said:
Indeed, the wavelengths of the spectral lines do depend on the radiation wavelength. Consider the typical energy of an x-ray photon (10nm-0.01nm), now consider the difference in energy levels between the lower shells (n=1, n=2 etc). Do these energy levels get close together, or futher apart as n increases?
Hootenanny said:
[...] what I was getting at is x-ray photons have a relatively short wavelength and are therefore very energetic. This means that xray photons are only absorbed/emitted by electrons which undergo large energy level transitions. Since, as you correctly say the difference between the energy levels decreases as [itex]n\to\infty[/itex], xray photons are only absorbed/emitted by electrons at the lower energy levels (since [itex]\Delta E[/itex] is greatest here).
Does that make sense?
I Hope this was helpful
As a scientist familiar with the interaction of X-rays and electrons, I can provide some insight into this question. The reason why incoming X-rays or electrons preferentially interact with the inner core electrons rather than the outer electrons is due to the concept of binding energy.
The outer electrons in an atom have lower binding energy compared to the inner core electrons. This means that it takes less energy to remove an outer electron from its orbit compared to an inner core electron. When an X-ray or electron interacts with an atom, it transfers its energy to the atom's electrons. This energy is then used to remove an electron from its orbit.
Since the outer electrons have lower binding energy, they require less energy to be removed and are therefore more easily ejected. However, the inner core electrons have higher binding energy and require more energy to be removed. This makes them less susceptible to ejection. Therefore, in most cases, the incoming X-ray or electron will interact with the inner core electron rather than the outer electron.
I hope this helps to explain why the inner core electrons are preferentially interacted with in the process of X-ray emission. If you would like to explore this topic further, I suggest looking into the concept of binding energy and its role in the interaction of X-rays and electrons.
1. What is the difference between X-rays and electrons?
X-rays are a form of electromagnetic radiation, while electrons are subatomic particles with a negative charge. X-rays have a higher energy and shorter wavelength than electrons, and can travel through materials that electrons cannot penetrate.
2. How do X-rays and electrons interact with matter?
X-rays and electrons interact with matter through a process called ionization, where they transfer energy to atoms and molecules in the material. This can cause the atoms and molecules to become excited or even break apart, leading to a variety of effects such as image formation in X-rays and electrical conductivity in electrons.
3. What are some common applications of X-rays and electrons?
X-rays are commonly used in medical imaging, material analysis, and security screening. Electrons have a wide range of applications, including microscopy, particle accelerators, and electronic devices such as transistors and computer chips.
4. How are X-rays and electrons produced?
X-rays are produced when high-energy electrons collide with a material, causing the electrons in the material to release energy in the form of X-rays. Electrons can be produced through a variety of methods, such as thermionic emission or particle accelerators.
5. What safety precautions should be taken when working with X-rays and electrons?
X-rays and electrons can be hazardous to human health, so proper safety precautions must be taken when working with them. This may include wearing protective equipment, using shielding and containment measures, and following proper handling and disposal protocols.
  • Atomic and Condensed Matter
  • Biology and Medical
  • Electromagnetism
