Electron Acceleration and X-Ray Emission in X-Ray Machines
In summary, an electron is accelerated and emits EM radiation of different colors or x-rays if the velocity is high enough. The radiation is necessary for the process of Bremstrahlung to occur. The radiation also occurs when an electron is decelerated. The radiation is emitted in a variety of wavelengths depending on the amount of acceleration. The radiation is emitted from an electron when it is accelerated or decelerated in a synchrotron type of arrangement. The radiation is emitted in a range of distances depending on the potential difference. The radiated power difference is on the order of 10^8.
AndresPB
28
Good morning all, I was just wondering the following question. When an electron is accelerated it emits electromagnetic radiation, depending on how much it is accelerated the energy varies so the frecuency does and the electromagnetic wave emitted would be of different colors or maybe even x-rays if the velocity is high enough. If this happens inside an x-ray machine, then why is it neccesary for the process of Bremstrahlung to occur? or K-shell emision? Would the electron alone be enough to generate x-rays or it is enough and the other fenomena occur only to generate more of them?
Biology news on Phys.org
It is a fact that accelerated charged particles radiate EM radiations of variety of wavelengths and even shortest wavelength x-rays can generated by pure acceleration or deceleration but a technology developes by its utility in various sector-
for example if one wishes to see fracture in a boiler frame he will need an intense beam of particular wavelength ,so a Mo target is used to get intense beam of about 0.7 angstrom.
similarly for various purposes a handy focussed x-ray tubes have been developed.
for general continuous x-rays one can use the 'simple x-ray device' but its not falling in particular range of wavelengths needed as well as 'intensity' is also an issue.
in most of the structure analysis /diffraction experiment cu-tube with copper as target are being utilised.
If one looks up the Intensity distribution of X-rays coming from a tube -the sharp peaks of 'characterist emissions' have large intensity difference from the continuous x-rays sector -thats why the target -tubes are popular than simple cathode ray tubes .
moreover for larger acceleration of a charge particle one needs a synchrotron type of arrangement where the particle can be pushed to large accelerated velocity -and synchrotron beams are also used in research and other scattering processes.
however the Roentzen Ray Tubes are still in the top rung.
Ok so i think we can conclude is that the acceleration via potential difference is not enough for a good amount of x rays to produce so the bremshtrahlung or characteristic emision processes are the ones that matter for this fenomena, my last question would be why does the order of magnitute affect this processes? Why a potential difference applied in a magnitud order of cm's achieve to emit a foton of less frecuency than a desacceleration process that occurs in the magnitute order of an atom? (Bremstrahlung)? Can someone put a formula?
I think the result that you're after essentially comes down to the fact that the power emitted by a point charge under acceleration or deceleration is proportional to the square of its acceleration. Look up the Larmor formula if you want the details.
So you're right that the distances over which the electron moves make the difference. The potential difference in an x-ray tube will accelerate electrons across a gap of ~10 cm or more. But then they strike a target material, the electrons decelerate over a very small distance. A 100 keV electron has a range of about 15 microns in Tungsten. So you're looking at a ratio of distances on the order of 10^4 under which an electron gains or loses it's energy. So I would guess the radiated power difference would be on the order of 10^8! And that's probably an underestimate given that the electron's path in the metal is not really a constant slowing, but rather brief instances of hard breaking interspersed within longer straighter path segments.
Likes AndresPB
1. How do X-ray machines work?
X-ray machines work by producing electromagnetic radiation in the form of X-rays, which are able to pass through soft tissues but are absorbed by denser materials such as bones and metal. The machine consists of an X-ray tube that generates the X-rays, a collimator that directs the X-rays towards the patient, and a detector that captures the X-rays after they have passed through the patient's body.
2. What type of energy is produced by X-ray machines?
X-ray machines produce electromagnetic energy in the form of X-rays. X-rays have a shorter wavelength and higher frequency than visible light, making them able to penetrate through materials that visible light cannot. This allows for the visualization of internal structures in the body.
3. How do X-rays interact with matter?
X-rays interact with matter through a process called photoelectric absorption. This occurs when an X-ray photon collides with an atom and transfers all of its energy to an electron, causing the electron to be ejected from the atom. The energy of the X-ray photon is then converted into heat or light energy.
4. What safety precautions should be taken when using X-ray machines?
When using X-ray machines, it is important to follow safety protocols to minimize radiation exposure. These precautions include wearing protective gear, limiting the time and amount of exposure, and shielding patients from unnecessary radiation. It is also important to regularly maintain and calibrate X-ray machines to ensure they are functioning properly.
5. How do X-ray machines contribute to medical diagnosis and treatment?
X-ray machines play a crucial role in medical diagnosis and treatment. They allow for the visualization of internal structures and abnormalities in the body, aiding in the diagnosis of various medical conditions. X-rays can also be used in radiation therapy to target and destroy cancer cells. However, it is important for medical professionals to carefully weigh the benefits and risks of using X-rays for each patient.
  • High Energy, Nuclear, Particle Physics
  • Quantum Physics
  • Nuclear Engineering
