X-ray Scattering: Bragg Spacing, D-Spacing, Q & Repeat Distance
In summary, Bragg spacing refers to the spacing between lattice planes in direct space, while d-spacing refers to the spacing between lattice planes in reciprocal space. The scattering vector, q, is related to the lattice spacing through the Laue diffraction conditions. To learn more about the basics of X-ray scattering, books such as Cullity's "Elements of X-ray Diffraction" and Als-Nielsen and McMorrow's "Elements of Modern X-ray Physics" are recommended, as well as solid state physics books.
thearny
33
bragg spacing? how does it differ from d-spacing? and where does q fit in? And finally are all of these directly related to the repeat distance?
Science news on Phys.org
Does anybody know a good source for information on the basics of X-ray scattering, my library has nothing since 1965, and that's unreadable!
Cullity: Elements of x-ray diffraction. 1st ed. came out in 1955 and it's still very useful. Latter editions are useful too but if your library doesn't have them you better be loaded because they're expensive. Als-Nielsen, McMorrow: Elements of modern x-ray physics is good too.
bragg spacing and d-spacing? I'm unfamiliar with this terminology. I suppose they mean lattice plane spacing in direct and reciprocal spaces but in which order? repeat distance means lattice plane spacing too I think.
q is the scattering vector. the difference between the incident and diffracted beam. it is related to the lattice spacing via the Laue diffraction conditions
[tex] q \cdot a=2\pi h[/tex]
[tex] q \cdot b=2\pi k[/tex]
[tex] q \cdot c=2\pi l[/tex]
where q is the scattering vector, a,b and c the lattice vectors in direct space and h,k and l the miller indices of the plane the beam is getting scattered from.
quite a few solid state physics books also have pretty good basic explanations of x-ray diffraction.
1. What is X-ray scattering?
X-ray scattering is a technique used to study the structure of materials by measuring the scattered X-rays produced when a beam of X-rays is directed at a material.
2. What is Bragg spacing?
Bragg spacing is the distance between two consecutive crystal planes in a material. It is named after William Henry Bragg, who first described this phenomenon in 1912.
3. What is D-spacing in X-ray scattering?
D-spacing, also known as lattice spacing, is the distance between two adjacent lattice planes in a crystal. It is often used to characterize the structure of materials using X-ray diffraction.
4. What is Q in X-ray scattering?
Q, also known as the momentum transfer, is a measure of the difference in momentum between the incident X-ray beam and the scattered X-rays. It is used to determine the size and spacing of particles in a material.
5. What is the repeat distance in X-ray scattering?
The repeat distance, also known as the unit cell length, is the distance between identical points on two adjacent unit cells in a crystal lattice. It is used to describe the periodicity of a crystal structure and can be calculated using the Bragg equation.
  • Atomic and Condensed Matter
