X-rays: trouble understanding
  1. Sep 28, 2016 #1
    Although not a computational problem, I still have difficulties understanding emission of characteristic X-rays.
    Can someone please clear up my confusions about the topic? Here's where I'm stuck, with two texts as an example:
    Source for the above: http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/xrayc.html
    Following this explanation, let's say we shoot out an electron from the K-shell, and an electron from the L-shell fills its place. The X-ray that will then be emitted will be of equivalent energy size as the difference between binding energies of the K-shell and L-shell of the atom.
    However, look at the following text:
    Source: https://www.bruker.com/products/x-r...ntal-analysis/handheld-xrf/how-xrf-works.html
    Here confusion begins. How can an electron have a higher binding energy if it is further away from the nucleus? Looking at this table, I can't understand how an electron further away from the nucleus can have higher binding energy: http://xdb.lbl.gov/Section1/Table_1-1a.htm
    My question is this: what type of difference of energy is an x-ray made of? The difference between the shells or the difference in the energy state of an electron?
    Hope my confusion made sense.
    P.S. Not used the template for posting assignment, since this is not a computational problem.
  3. Sep 28, 2016 #2
    Staff: Mentor
    The second text is in error: it should be higher potential energy, not binding energy.
  4. Sep 28, 2016 #3
    Jonathan Scott
    The amount of energy that has to be supplied to remove the electron is greater when it is closer to the nucleus, so the binding energy has the opposite sign to the potential energy of the electron. I think it should refer to higher potential energy, not binding energy.
  5. Sep 28, 2016 #4
    Staff Emeritus
    Education Advisor
    There might be a confusion due to the SIGN.
    A binding energy is often quoted with the knowledge that it is negative. For example, the ground state of H atom is Eb = -13.6 eV. While the magnitude of the binding energy is large, it is considered to be "lower" than, say, the vacuum level which, by definition, has 0 eV. So mathematically, the vacuum level has a "higher binding energy" than the ground state.
  6. Sep 28, 2016 #5
    DrClaude and Jonathan Scott
    That certainly clears up my confusion! Thanks for pointing that out!
Have something to add?
Draft saved Draft deleted
Similar Threads - rays trouble understanding Date
I Identification of index of Bragg peaks for NaCl Feb 4, 2018
I How to index single crystal Bragg peaks Feb 4, 2018
I Laue Diffraction Intensity Distribution Nov 28, 2017
I X-ray diffraction minima? Sep 21, 2017
Having trouble with Density of States Jun 18, 2015
