Y delta 3 phase
  1. May 19, 2013 #1
    Hello,
    For our final lab we will be given a box with three wires, the neuter is missing. In the box there is a Y or delta configuration and we can use everything to find out if it is a Y or a delta configuration. So, voltmeters or watt meters, or even something like tin foil. Can someone help us? It’s the last lab. And it’s the only one we don’t understand.
    Thank you
  3. May 20, 2013 #2
    NascentOxygen
    Staff: Mentor
    Hi MyYdna. [Broken]
    Am I to understand that the box contains three resistors, connected either in Y or ∆ and you have to determine which configuration?
    Your first step is to draw the two diagrams. Then in your mind consider making measurements, or connecting meters, or voltages, etc., to any or all of those 3 terminals.
    BTW, the spelling is "neutral".
  4. May 20, 2013 #3
    I did the things you said. And you are correct, three resistors. Apparently we made a mistake in our readings (we used volt and amp meters). That's why we couldn't understand it. And yes. We may use everything. So also a thermal camera. :)
  5. May 21, 2013 #4
    NascentOxygen
    Staff: Mentor
    So this is now solved? How did you make your determination (and without using X-rays or a thermal camera)?
Have something to add?
Draft saved Draft deleted
Similar Discussions: Y delta 3 phase
  1. Delta-to-Y, Y-to-Delta (Replies: 2)
Loading...
