Yacc/bison and C problems
  1. Oct 13, 2008 #1
    Ok, so first I want to do a type checking to my yacc code. The partial code I have is below:
    What must I add to the code so that I can access $1.type? I already defined:
    typedef struct Type{
    int type;
    } Type
    %union{
    int typ;
    %type <typ> expr
    However it still doesn't work
    Code (Text):
    expr   : '-' expr %prec UNARY {$$ = -$2}
           | '!' expr %prec UNARY {$$ = !$2 }
           | expr '+' expr {
              if ($1.type != INTEGER || $3.type != INTEGER)
                    fprintf(stderr, "Invalid type for addition, must be an integer\n");
              else
                     $$.type = INTEGER;
           | expr '-' expr {
                    fprintf(stderr, "Invalid type for substraction, must be an integer\n");
              else
                     $$.type = INTEGER;
           | expr '*' expr {
                    fprintf(stderr, "Invalid type for multiplication, must be an integer\n");
              else
                     $$.type = INTEGER;
           | expr '/' expr {
                    fprintf(stderr, "Invalid type for division, must be an integer\n");
              else
                     $$.type = INTEGER;
           | expr EQ expr
           | expr NE expr
           | expr LE expr
           | expr '<' expr
           | expr GE expr
           | expr '>' expr
           | expr AND_OP expr
           | expr OR_OP expr
           | ID opt_idexpr
           | '(' expr ')'
            | '(' error {fprintf(stderr, "Missing expression after '(' \n");}
           | INTCON {
                      $1.type = INTEGER;
           | CHARCON {
                      $1.type = CHARMARK;
           | STRINGCON {
                    $1.type = STRINGMARK;
    All I want to do here is so that I can do $1.type or $2.type, so therefore I know what type is $1 or $2 and the type is basically something that I have defined in top of the file, something like:
    #define INTEGER 1
    #define CHAR 2
  3. Oct 16, 2008 #2
    When you create %union, it's your yylval variable in lex. Hence when your make actions for the regular expressions in lex you can access the type as yylval.type.
    The $'s are the parts of your recursive tree, for i.e.
    S:EXPR ',' EXPR2
    $1 = EXPR
    $2 = ,
    $3 = EXPR2
    $$ = S
    you receive those from lex not from yacc.
