Yet another induction proof
theperthvan
184
Prove the following using induction:
[tex]cos(n\pi + x) = (-1)^ncos(x) [/tex]
Let [tex] cos(k\pi + x) = (-1)^k cos(x)[/tex]
True for k=1
Right Hand Side...
[tex](-1)^{k+1}cos(x)[/tex]
[tex]= -(-1)^k cos(x)[/tex]
[tex]= (-1)^k cos(x)[/tex]
Since [tex](-1)^{k+1}cos(x) = (-1)^k cos(x)[/tex]...
Not too sure where to go from here.
Answers and Replies
cristo
Staff Emeritus
74
Why not take the LHS [itex]cos((k+1)\pi +x)=cos([k\pi +x]+\pi)[/itex] and use the double angle formula: cos(a+b)=cosa cosb-sina sinb?
matt grime
9,426
Are you claiming that's a proof for k=1, an attempt at a proof for k=1, or are you stating it is true for k=1 without any proof?
Anyway, this is about proof by induction, and obviously the left hand side is the thing you're going to want to attack inductively (since there is an obvious way to write k+1 as k plus 1 and you know you're trig formulae (cos(A+B)=cos(A)cos(B)-sin(A)sin(B) for instance...)
theperthvan
184
I did the LHS, and got
[itex]cos((k+1)\pi +x) = cos(k\pi +x)[/itex]
and from before,
And so from that, and the initial statement, does that prove it?
mjsd
726
and from before,
err.. isn't [tex](-1)^{k+1}\cos(x) = (-1) (-1)^k \cos(x)[/tex]
so using your assumption:
[tex]LHS=-\cos(k\pi+x)=\cos(k\pi+x+\pi)...[/tex]
ans so on... all too easy :smile:
matt grime
9,426
this is wrong: look at the graph of cos(x).
and from before,
this is also wrong: you've just said 1=-1.
theperthvan
184
Oops, silly mistake.
So let me try this again,
[tex]cos(k\pi + x) = (-1)^kcos(x)[/tex]
RHS
[tex](-1)^{k+1}cosx = -(-1)^{k}cosx [/tex]
LHS
[tex]cos[(k+1)\pi + x] = cos[(k\pi + x) + \pi][/tex]
using double angle formula,
[tex]= -cos(k\pi + x)[/tex]
And so, [tex]cos[(k+1)\pi + x] = (-1)^{k+1}cosx[/tex]
=> [tex]-cos(k\pi + x) = -(-1)^{k}cosx[/tex]
kill the negatives
[tex]cos(k\pi + x) = (-1)^{k}cosx[/tex]
Cheers,
cristo
Staff Emeritus
74
RHS
LHS
Here, you've assumed that the statement holds for n=k+1, and used this to prove for n=k. This to me doesn't seem right, as surely you need to show that the statement holding for n=k => the statement is true for n=k+1.
To do this, we suppose that [itex]\cos(k\pi+x)=(-1)^k\cos(x)[/itex] is true. Now, we use this to prove that it hold for n=k+1; [tex]\cos([k+1]\pi+x)=\cos([k\pi+x]+\pi)=-\cos(k\pi+x)=-(-1)^k\cos(x)=(-1)^{k+1}\cos(x)[/tex] , where we note that the penultimate equality holds from our inductive hypothesis that [itex]\cos(k\pi+x)=(-1)^k\cos(x)[/itex]
matt grime
9,426
What are you doing? LHS and RHS of what? Not what you wrote one line above.
Induction proofs are taught by rote. So reproduce the style of proof.
And don't write things going from both sides like this. Sure, that's often how you work out what's going on (to get from A to B yo go from A to C and from B to C as well). What you write should be a simple argument with no jumping around:
It's trivially true for n=1.
Consider cos(pi(k+1)+x), and simplify it and now use the inductive hypothesis that the result is true for k (and everything between 1 and k as well if necessary - it isn't in this case).
Suggested for: Yet another induction proof
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
