Yo-Yo problem
  • Thread starter atm1993
Given the following Rdisk = 2.50 cm, Raxle = 0.250 cm, Mdisk - 25.0g, Maxle = 0.750g
a. Determine the rotational inertia of a yo-yo about it's center.
b. Dervie using force and torque the expression for the linear acceleration of a yo-yo
c. Calculate the a of the yo-yo for the given values
I = (1/2)mr^2
Iα = τ
Part a. pretty simple, I think I did it right. Using the moment of inertia equation for a disk, just add 2xthe I of the disks, and the I of the axle, didn't have a problem for that, got 156gcm^2.
Part b. I wasn't completely sure if I was doing right. I started with mg-T = ma and went from there. τ=Fr, so the force in this case is the tension, so
τ=(mg-ma)r, and since τ= Ia, and also a = (a/r) I got eventually
a = mgr^2/(I-mr^2). Did I do this properly?
Part c. was plugging in the numbers. I was a little confused about r, r would be the radius of just the axel right? Using that, I got 20.4 cm/s^2.
I'm a little iffy on the whole thing, so hopefully I can get some help.
Answers and Replies
kuruman
Insights Author
2,834
I = (1/2)mr^2
Iα = τ
The method is correct. Redo the numbers and if you get the same answer, you are OK here.
*** On edit ***
Not quite. Recheck the algebra.
Related Threads on Yo-Yo problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
