Why is light from a single source incoherent?
In summary, light from a single source is not necessarily coherent. The degree of coherence is low for most light sources, but a single slit can improve the level of coherence by behaving like a point source. However, only laser light is highly coherent due to its design that ensures in-phase and monochromatic light production. Incoherence in light sources is related to their design, such as in the case of an incandescent light bulb where the light is produced through heat and results in varying wavelengths and phases.
zmike
139
Just a quick q,
My book says that to make the light source young used to be coherent, he passed it thru a SINGLE slit THEN passed it thru a double slit. Why would he do that? couldn't he just put the light source directly to the double slit? I thought all light from a single source was coherent?
thanks
The degree of coherence is very low for most light sources. The single slit would improve the level of coherence.
Only laser light is highly coherent.
why would a single slit improve coherence?
why is a single light source incoherent? doesn't light from a single source have a frequency and intensity that is identical?
Any light source can be treated as the collection of large number of point sources. According to the Hygiene's wave theory, each point source forms a wavefront which propagates in the forward direction. So at any point from the source several wave front can reach there producing in coherent light. Due to diffraction, a narrow single slit can behave like a point source.
Incoherence is related to the type of light source. The design of a laser generally permits the produced light to be in phase (coherent) and of the same wavelength (monochromatic). Compare that with an incandescent light bulb. The light bulb has a filament that gets hot, which results in the production of light. However, the light emitted ranges over a variety wavelengths--about 10% of the emitted light is in the visible spectrum and the rest is in the infrared spectrum--so it is polychromatic. Light from a light bulb is incoherent because the light production is heat driven and the temperature variations cause the electrons to jump from orbital to orbital in a random manner.
What is the Young's double slit experiment?
The Young's double slit experiment is a classic experiment in optics that demonstrates the phenomenon of interference. It involves shining a single beam of light through two parallel slits and observing the resulting interference pattern on a screen.
What is the purpose of the Young's double slit experiment?
The purpose of the Young's double slit experiment is to demonstrate the wave nature of light and how it can interfere with itself to create patterns. It also helps to support the wave theory of light and disprove the particle theory of light.
What is the difference between single slit and double slit interference?
The main difference between single slit and double slit interference is the number of slits used. In single slit interference, a single slit is used to create a diffraction pattern, while in double slit interference, two parallel slits are used to create an interference pattern. Double slit interference results in a more complex pattern due to the addition of the interference between two waves.
What factors affect the interference pattern in the Young's double slit experiment?
The interference pattern in the Young's double slit experiment can be affected by several factors, including the wavelength of the light, the distance between the slits, and the distance between the slits and the screen. Changing any of these factors can alter the interference pattern and provide valuable insights into the nature of light.
How is the Young's double slit experiment used in everyday life?
The Young's double slit experiment is used in everyday life in various applications, including optical devices such as cameras, telescopes, and microscopes. It is also used in the development of technologies such as holography and interferometry, which have many practical applications in fields such as medicine, engineering, and astronomy.
  • Quantum Physics
  • Quantum Physics
